3054 steering wheel
/ 3054 steering wheel #1
Jim_in_Omaha
Omaha area
LK3054
I noticed that my steering wheel seems to float around now like its mounted in rubber. So I took it off and removed the dust seal on top of the steering tube. There looks like there is a rubber type material bushing in there. But whats odd is I did not notice this much movement in the beginning. Does anybody elses do this? I must be loosing my mind.. /forums/images/graemlins/confused.gif
Jim
/ 3054 steering wheel #2
Other than a little free steer the wheel feels solid. Spent 6 hours in the seat today discing. /forums/images/graemlins/grin.gif
/ 3054 steering wheel #3
Jim, I saw this problem on another Kioti tractor just before I bought my CK20. As I understand it, and I think Ken Sweet or Jon DePratt mentioned that there is a nut in there that may need to be replaced. On the tractor I saw, the wheel worked, but could be "wobbled" on the shaft. Not a BIG deal, but not the way it should have been. I think this was a common problem on earlier models, and may still be for all I know. I'll deal with it when it happens to mine if it does. I think I heard that repair was about $75. John
I have the service manual and it shows very little as far as the steering shaft. It goes through the column assembly (tube) and has a spring pin that attaches to what appears to be the worm shaft that goes into the steering box. This tractor is a 2002 model.
The manual only shows that there is a "column bush" at the top of the column tube. I'm guessing that is what's causing the wobble. If anyone has some drawings from the parts manual it would be greatly appreciated. After 35 hours of hard use my tractor is falling apart. /forums/images/graemlins/wink.gif
thanks
Jim
/ 3054 steering wheel #5
Jim
Here is a breakdown of it. It’s not the best in the world. Im trying to get a better one, this one is folded in the middle a bit. As far as the wobble goes most of that is usually in that rubber bushing, reason they don't put a bearing or something is to keep vibration down. We have thought about putting in a harder poly bushing in some but haven't yet. The shaft on that column isn't solid, it’s a 2 piece shaft that is held together by a pin and is allowing some movement side to side, so that may be some of your movement too. I’m not sure about the nut deal, maybe Ken knows. /forums/images/graemlins/confused.gif
/ 3054 steering wheel #6
Come to think of it, I believe it was Wallace (another dealer) who mentioned this problem. It was in a thread related to warranty issues, or the lack thereof for Kioti Tractors. The person was saying that this was one of the only warranty issues he had had to deal with as there weren't many others. John
Thanks for the graphic Jon,
Whats happening is that the top steering shaft (#400) is floating around in the bushing (#200) in the graphic. It would appear that this is normal perhaps? It might be that me getting on and off the tractor a billion times when I was moving rather large trees might have helped break in that top bushing and I'm now just figuring it out that it floats anyway. It has about 1/4" side to side movement..
thx
Jim
/ 3054 steering wheel #8
I have found it to be normal to have some play in these columns. I wouldn't worry about it unless it just really bad. What year tractor is yours again? And how many hours?
Its a 2002 according to the serial number.
thanks
Jim
/ 3054 steering wheel #10
I have 180 hours on my CK20 and no wobble at all. Maybe you're right about the on and off the tractor, using the wheel to pull yourself up, but maybe it wasn't a good bushing in the beginning. The tractor I mentioned in my earlier post drove just fine, but the wobble was very noticeable. I wouldn't worry about unless it starts messing up the steering. John
/ 3054 steering wheel #11
Your CK shouldn't ever have a wobble problem. You have a differnet design steering column, like the DK's and the new LK3054xs. The only steering columns that will wobble would be the older LK's. They have a 2 piece shaft, where all the others have a 1 piece.
/ 3054 steering wheel #12
</font><font color="blue" class="small">( The only steering columns that will wobble would be the older LK's. They have a 2 piece shaft, where all the others have a 1 piece. )</font>
And the LB1914 older models at least. That's the one I first saw that had the wobbling steering wheel. I'm still not sure that it's the shaft at all, but the bushing that caused that problem. I guess you would have had to see it for yourself. John
/ 3054 steering wheel #13
Ya some of the older LB's did, not as bad as the LK's though. A lot of it is the bushing, but the 2 piece shaft doesn't help the problem. The upper shaft just fits on the lower shaft loosely and is held in place by a pin. This design allows the upper shaft to wobble side to side on the lower shaft.
/ 3054 steering wheel #14
I have an lk3054 2002 and mine is the same way 135hrs on it and it did the same thing. It had play from new and by pulling on it to get on and off the tractor it loosened up a little bit, doesnt seem to be getting any worse. I am not worried about it doesnt effect operation at all. When it starts rubbing metal i will replace it.
PALLET OF FLANGE CUT-OFF VALVES (A68842)
PALLET OF FLANGE...
2012 KENWORTH TROAXLE BODY  LOAD (A67714)
2012 KENWORTH...
2013 CHEVROLET CAPRICE CAR (A66091)
2013 CHEVROLET...
Year: 2018 Make: GMC Model: Terrain Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 116,222 Pla... (A66738)
Year: 2018 Make...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
2008 FORD F350 CREW CAB STAKE BED TRUCK (A66091)
2008 FORD F350...
