3054 in pond
/ 3054 in pond #1
kiotirules
georgia
kioti lk3054 4x4
hey fellas, i was cleaning around my pond and pulled the tractor up to the bank to get off just for a minute to pick up some brush, next thing i see is the tractor coming right at me, i did'nt set the brake or put the box blade down, i'm telling you this so it may never happen to you, not to let you know my stupidity. just be carefull!
/ 3054 in pond #3
Accidents sure can happen in a hurry. Glad you are OK.
Now, about the pictures...:D
David
/ 3054 in pond #4
Like David inferred..."Stuff happens"
Glad to hear you got out of the way.
Unfortunately, an occurence like this begs for some details, i.e.,
1) did it go "all the way" in the pond?
2) Did you get it out?
3) Did it start back up?
3) Does your wife/GF/mother/next door neighbor have any pictures they'd like to share?
Seriously, glad no one was hurt.
Tom
/ 3054 in pond #5
Hope you live far enough off the road that nobody saw it happen, could be a bit embarassing.:) Glad you are not hurt, that's the most important thing.
/ 3054 in pond #6
I submarined a new 135 with 25 hours on it, my first brand new tractor at 20 yrs. old. Was backing up to the edge of a pond with bush hog when the bank caved. Engine hot and at max RPM's, pulling in 1st high as hard as it could dig when the breather hit the water. Rode it all the way down. Probably the longest walk home I ever made. Dealer replaced 3 bent connecting rods and changed out the fluids, proved to be the best tractor I ever owned.
A hired hand sunk my JD "M" in a different pond about 6 months later, but luckily it was only idleing and did no mechanical damage.
My buddies found a sub commander's hat, bought and gave it to me for my 30th birthday. One of my most prized possesions.
I am a witness that tractors do not float....at all:D
/ 3054 in pond
hey! i thought about pics after i got it out, they would have been good. it went about 20 feet out just idleing, all i could see was lights under water and the canopy. lesson learned!!!
/ 3054 in pond #9
Highbeam said:
So did it suck water into the engine and die or was 20 feet out still too shallow?
Hey Beam,
Im kinda wonderin the same thing :) Pics would have been great especially if tractor and operator were OK !!!
/ 3054 in pond
well i have got tractor running again after much work. i have a problem with the tractor smoking white/ blue. i changed the injectors and cleaned the fuel tank of all water. at start up the smoke is thick, after i run for about 30 mins it gets alot better, also i have a small skip, and if it sits idleing the engine will rev-up and go back to idle and repeat. any ideas on what to check, or does it just need to be ran awhile?? please help!!!
