3054 erratic tachometer
/ 3054 erratic tachometer #1
wanasrx
Bronze Member
NY
Kioti 3054
My tach seems to be malfuctioning. It's jumping around and is mostly pinned at the max. It was Ok all summer. Any Ideas?
Thank you
/ 3054 erratic tachometer #2
Check the connection where it goes into the tack housing in the front of the engine by the injector pump.
If it is tight and still doing it then take the end loose and spin the cable with your fingers and see if the tach on the dash moves.
I'll give it try and let you know how I make out.
Thank You Wallace
I finally checked it out.(after tach needle snapped off). Took cable off at engine location. Cable spins fine and needle moves(whats left of it). Put a couple drops of oil in engine part and put it back on. Seems to be working OK.
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
11R24.5 Tires - Set of 4 (A68134)
11R24.5 Tires -...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
BANDIT 72FM-72" HYD MULCHING HEAD (A65056)
BANDIT 72FM-72"...
Club Car Emergency Cart (A64557)
Club Car Emergency...
