3033R ROPS %^*(*%$#!
/ 3033R ROPS %^*(*%$#!
I have a 2025r and have the same problem. I usually leave mine in the head banging mode most of the time. I put a 5 gallon bucket in front of 5he door when I put the ROPS up. I should say most of the time since I bent stuff up the house once.
... yet one more reason to leave it down. I can’t claim I’ll always remember to get off the tractor and fold it at the end of a long hot day working outside.
Agreed zzvyb... I’m actually one of those engineers responsible for making similar safety considerations, it’s all about statistics, and limiting the company’s net liability cost. It’s not always about making the most sensible choice, it’s about making the choice that can be defended in court, or sometimes preventing a few very large but infrequently liabilities at expense of numerous smaller cases, based on how the numbers shake out.
Ironically, my shop did previously have taller doors, but since the shed where I usually keep the tractor has a low roof, I’m stuck at 7 feet there. Here’s where it’s at, now:
/ 3033R ROPS %^*(*%$#! #12
Seriously, if there is clearance below the rafters and lights, I'd be looking at modifying the door opening.
I hear you, but there is not. Not even close. This ROPS is over 9 feet tall, and those rafters are only 8’-6”. Besides, I don’t normally keep the tractor in my shop, it’s normally in a shed where the roof rafter crosses the top corner of the door right at 7 feet. Besides, I have at least 50 trees in my yard with branches that would hit the ROPS in the up position, and lopping the branches off all of them is not an option. I am not really worried about rolling this machine, given what I do with it.
/ 3033R ROPS %^*(*%$#! #14
Maybe swap the factory ROPS for a custom roll cage. Much lower height, better protection from those snapping branches. Cooler looking. :)
roll cage
/ 3033R ROPS %^*(*%$#! #16
I should have read down before posting, you explained it clearer than I. :)
/ 3033R ROPS %^*(*%$#! #17
In regards to folding ROPS. If the operator isn't going to place it back in the upright position every time it's not hitting something, might as well unbolt it and be done. A folded ROPS isn't worth hauling around.
/ 3033R ROPS %^*(*%$#! #18
Meh...I'd rather be doubled over under the shortened height of a folded ROPS than flattened under the weight of the tractor lying on me.
...of course the chances that anybody would be wearing their seatbelt while having the ROPS folded are slim to none.... so maybe "might as well unbolt it and be done" is right.
/ 3033R ROPS %^*(*%$#! #19
Don't remove it. A folded rops does in fact add tremendous strength to the vertical rops supports as it ties them together. During a roll over. it would have to bend many tubes VS just the one on one side. Like the OP, there is little reason to need a rops in the vertical position because the land is flat. Low limbs are a endless obstacle. Now that I have a cabbed toolcat, I HAD to cut branches. I used my work platform and had the wife drive me around to do some trimming. It was well worth it and the property looks like a park.
/ 3033R ROPS %^*(*%$#! #20
Drill a small hole in the bracket that you can put a pin in so that it will be above the hydraulics when folded (on each side). It’s a pain if you’re trying to hook up something on the 3pt because it’s more in the way, but it’s out of head banging height. Also, hang something from the garage door at eye level as a reminder to check ROPS up/down position —tennis ball on a string.
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2025 MMS MS36CJ (A60463)
2025 MMS MS36CJ...
2020 Deere 317G (A60462)
2020 Deere 317G...
(INOP) 2009 FORD CROWN VICTORIA (A59823)
(INOP) 2009 FORD...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
