Mowing 3032e PTO issues
/ 3032e PTO issues #1
Jeremy Hammack
Inez, TX
3032e
I have a 3032e that is not engaging the PTO when the switch is engaged. I have replaced the switch, checked the fluid, checked the safety switch under the seat and nothing.I have removed the shredder to eliminate that and can turn the shaft ( not easily) with a wrench. The light on the dash will come on when the switch is engaged. No engine noise at all when engaging. I have revved up the RPms and put in gear, forward and backwards. NOTHING. What am I missing?
Jeremy
/ 3032e PTO issues #2
I have the same problem with my 3032E. I also pulled the solenoid and checked it by connecting a 9 volt battery to to as advised by the dealer. It was fine. I'm at wits end. Have ordered a 3032E Technical Manual on CD. Hoping this will help.
Quick Attach Backing Plate (A65579)
Quick Attach...
New/Unused AGT Industrial SDA-140T Track Loader (A65579)
New/Unused AGT...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
