3020 Rockshaft Controls
   / 3020 Rockshaft Controls #1
Draagyn
Woodpecker, Canada
65 JD 3020, 75 IH 966
My tractor didn't come with a cable to control the Rockshaft.
I just bought a new one and in the process of installing.
I will be able to get it to work, but I believe the mounting brackets are no longer on tractor.
Could anyone take pics of theirs so I can see how they are mounted?
Thanks!
   / 3020 Rockshaft Controls #2
This parts photo is all I can come up with.
   / 3020 Rockshaft Controls #3
Clamp#34 bolts to the side of the rockshaft housing, just behing ght rockshaft lift arm. route the cable under the arm and clamp it in place with the 5/16" bolt. CLamp #410 bolts to the control support directly under the control lever. Should be a square 5/16" hole tha the bolt goes through and is secured with a nut.
Thanks for the info jd110. I'll check this out next week, see how it goes
2017 Chevrolet Express 2500 LT Passenger Van (A51692)
2017 Chevrolet...
2025 CFG Industrial H15R (A50123)
2025 CFG...
11ft S/A Fuel Tank Trailer Frame (A51692)
11ft S/A Fuel Tank...
1995 Ford L8000 Grain Truck GARAGE KEPT (A53473)
1995 Ford L8000...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
Valvoline 6 cases manual transmission oil plus 11 (A53117)
Valvoline 6 cases...
