3020 Rockshaft Controls
   / 3020 Rockshaft Controls #1
Draagyn
Woodpecker, Canada
65 JD 3020, 75 IH 966
My tractor didn't come with a cable to control the Rockshaft.
I just bought a new one and in the process of installing.
I will be able to get it to work, but I believe the mounting brackets are no longer on tractor.
Could anyone take pics of theirs so I can see how they are mounted?
Thanks!
   / 3020 Rockshaft Controls #2
This parts photo is all I can come up with.
   / 3020 Rockshaft Controls #3
Clamp#34 bolts to the side of the rockshaft housing, just behing ght rockshaft lift arm. route the cable under the arm and clamp it in place with the 5/16" bolt. CLamp #410 bolts to the control support directly under the control lever. Should be a square 5/16" hole tha the bolt goes through and is secured with a nut.
Thanks for the info jd110. I'll check this out next week, see how it goes
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A52377)
2021 Fleco DX140...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
2006 FORD F-150 PICKUP (A54313)
2006 FORD F-150...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
