3020 Repair Manual?
   / 3020 Repair Manual? #1
imabass
Pawnee, OK
JD 3020 Propane
Which one to buy? There are several different versions available at prices from $30-100+. There are newer versions and the original dealer shop manuals. Not sure if there is much difference (like a haynes vs chiltons manual)
Basically looking for a fairly detailed repair manual for early (1964) propane 3020.
Id consider a pdf but prefer to have the paper copy for ease of use in the shop.
   / 3020 Repair Manual? #2
IMAO the Deere versions will be the most detailed. There used to be two books sm2038 and sm2039, today there is no more sm2039 and instead that info is in the FOS manual, which can be helpful if you don't have a strong understanding of the theory of operation, sm2038 is the actual tech manual. If I remember correctly there is also a separate manual for the hyd pump, but could be (and often am) wrong. You will spend the most $ on paper copies, cd's etc will be the lowest price.
   / 3020 Repair Manual? #3
You can see all the diagrams for free on jdparts.Com sometimes that is enough to get things apart.
New 40ft High Cube 6 Door Container (A53002)
New 40ft High Cube...
2020 INTERNATIONAL MV607 24FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
2003 International 4300 Dump Truck, VIN # 1HTMMAAL83H562953 (A51572)
2003 International...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
