3020 hydraulic issue
/ 3020 hydraulic issue #1
JaredWardall
John Deere 3020
Hi
I致e got a 69 3020 and am having a issue locating a problem with the hydraulic system. After running the tractor for awhile and the hydraulic oil is warmed up it starts to make a whinning/squeeling noise. All functions work as they should. Looking for quick help before I start with pressure testing. Has anyone had a similar situation? Thanks.
/ 3020 hydraulic issue #3
I'll suggest to get a laser thermometer & take temp readings of individual hyd components. The hyd component with the highest temperature would require a closer inspection for possible internal hyd pressure leakage.
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
Screen USA CF35D2 Tri Axle Towable Trommel Screener (A61572)
Screen USA CF35D2...
2024 John Deere 6R 145 Tractor (A63111)
2024 John Deere 6R...
2026 Electric Tricycle (A64194)
2026 Electric...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
