3016
   / 3016 #1
jacobsdaddy06
NW Arkansas
MF1240
Does anybody on here have or seen any of these new units yet? Just curious as to what price point these units where going to be.
   / 3016 #2
Have some on my lot...I'll even part with one;)
Shuttle with a loader for around $16,500
   / 3016
Only one problem with that I'm a ways away from you lol. I had a local dealer give me that price on a 3316 last week
   / 3016 #4
Daddy06
What state are you in?
   / 3016 #6
Are the 3 pt arms telescoping on the mahindra's like the kioti or bobcats?
   / 3016 #8
Many dealers have them in stock now. I really like the tractor. The ML115 loader is also very nice, with a lift capacity of about 1650 lbs. The tractor is comfortable to operate and built very well. I'd recommend you buy two of them. :D
   / 3016 #9
just curious as to why are they discontinuing the 2816? would you try to find a 2816 or pass for the 3016
   / 3016 #10
The 2816 has been around, in various forms and with various nomenclature for around a decade. It is getting a little dated regarding it's features and specs. Some things are minor like rubber floormats vs the perforated steel, newer style lights, telescoping sway bars instead of turnbuckles, etc. On the flip side, the 2816 it is a tried and true model, and has always been a high volume seller. The big advantage to the 3016 is loader lift capacity. The 2816 is a very adequate 1035 lbs, the 3016 is 1650. On the gear models, the 30 is a shuttle, the 28 is not. On the HST, the 30 uses a newer style pump that is a little quiter and smoother, like the current 3316. However, a good deal on a 2816 should certainly be considered. It's a rock solid tractor. We started February with 9 2816's remaining at our place, and we are down to 3...so act fast or they will be gone at your local dealer as well. I would not hesitate to go with the 28, unless you are lifting really heavy stuff with the FEL on a regular basis.
Genie GTH-644 (A50490)
2011 PETERBILT 348 (A52472)
2011 PETERBILT 348...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2010 Nissan Rogue SUV (A50324)
2010 Nissan Rogue...
John Deere MX5 3pt 60" Rotary Mower (A50774)
John Deere MX5 3pt...
