nmu98
Veteran Member
- Joined
- Jun 1, 2007
- Messages
- 1,132
- Tractor
- JD 5203, JD 3720, JD 4110, JD 445, IH 1586, IH 886, IH 404......
Update: My neighbor was a machine repairman at GM and we were discussing the problem. I was telling him that 2 dealers told me to put the bucket under something it could not lift, and at full rpm hold the lever over to lidt for 10 minutes. Whatever cyl gets hot is the one leaking by.
Thinking there had to be a better way, I was discussing it and telling him it seemed to hard on the equipment. My neighbor told me to raise the cyl all the way in, then remove the line at the top of the cyl. once removed, I would try to compress the cyl more. If the cyl is leaking, fluid should come out, if it is not leaking, nothing would come out.
When we pulled the top line off, we fgot a little fluid out, he held the line away from us, and I pulled the lever over at 1400 rpms. The first one did not leak. The second one had a good solid line of fluid leaking.
I now know that I have an issue with the right cyl.
I thought I would share this as it was so easy that we checked the rest of the cyl on the tractor. I have no clue why me dealer would not tell me this, or tell me that they test them this way. Anyone who thinks they have this issue should try it. If needed, I could take a movie and do it again. Very Simple!
