3000 Ford
/ 3000 Ford #1
klhilton
Kubota L3400
I have a 3000 ford tractor and fuel is leaking around the fuel shutoff and throttle lever going into the injector pump. Can the seals be changed without tearing the pump apart?
Thanks for any information on this.
/ 3000 Ford #2
Welcome to TBN.
Maybe should have given a better description in your thread title. There's a guy on here that is a pump expert and he would know. Maybe he'll stumble onto this thread.
/ 3000 Ford #3
Yes, it can usually be done on the tractor w/ the pump still attached..
There are MANY posts & video's on it.. some successful & some not..
Just google, CAV DPA top cover leak.. or.. CAV stuck metering valve..
THAT'LL keep ya busy for awhile..
They sell a mini gasket kit on ebay that has all the gaskets for JUST the top cover..9-12.00 w/ free shipping.
I suggest getting the gaskets BEFORE u lift the cover & try to fix it..
Some of the time orings wont fix the leak.. the shafts are steel that move in an aluminum top cover..
Dirt or other contam. get in the shafts & eat a groove on the cover..
So when u get the cover off & the shafts out, look to see if there are any grooves in the bores..
If yes, u can try the new orings.. u have nothing to lose.. but if it doesnt stop the leaks, I can put teflon bushings in them.
OR u can buy a new top cover..
/ 3000 Ford
Thank you very much, I see I did get a reply from thepumpguysc that is very helpful.
/ 3000 Ford
Thank you, I will do some searching.
2019 JOHN DEERE 325G SKID STEER (A65053)
2019 JOHN DEERE...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A64553)
2025 BrushFox...
2011 HMDE GOOSENECK SPOOL TRAILER (A65643)
2011 HMDE...
(5) Steel Wheels (A65640)
(5) Steel Wheels...
(4) 11R22.5 TIRES ON STEEL WHEELS (A64277)
(4) 11R22.5 TIRES...
Wolverine Quick Attach Brush Cutter (A66408)
Wolverine Quick...
