$300 to load rear tires
   / $300 to load rear tires #23
Many dealers will sell you rimguard to install yourself. I bought my Rimguard and pumped it in myself.
   / $300 to load rear tires #24
Messicks in PA sells a 55 gal drum of Sprayer Winterizer for $109. I would think this should work in tires if you're not looking for the maximum weight of Rimguard or CaCl.
Or maybe you can find something at local marine or RV store for similar price per gallon.
Why don't stores sell the RV type stuff in concentrate so you could mix your own, or can that stuff not be diluted with water? Seems expensive to package and ship the diluted stuff, even in 55 gallon drums?
   / $300 to load rear tires #25
I paid $750.00 to have the rear tires filled with Agrim-lim 50 on my LS7010. LS7010.jpg
   / $300 to load rear tires #27
Rim Guard (-34f) is about .28cents a gallon +/- and can only be installed by a dealer.
I know this price is wrong. At that price I could fill my 7010 for $45.36 (162 gallons). Even at 2.80 per gallons only cost $453.60. That sounds more like it but still only 60% or what Ralph Copp paid for the agrim-lim which I have heard nothing about. I wonder if it is a calcium chloride type or some type of lime based.
   / $300 to load rear tires #28
I paid $750.00 to have the rear tires filled with Agrim-lim 50 on my LS7010. View attachment 301225
Actually a little mis-spelling there. It is Agri-Lim and is only available in Ontario Canada according to their website.
Seems a bit more expensive than the Rimguard but might have more weight. Web says it not corrosive and good to -50C.
Agri-lim inc.
   / $300 to load rear tires #29
I know antifreeze in cars gets weaker as it ages, does this happen when its in a tire, or is the aging due to running through a pump and the heat cycles? I havent filled mine yet, not sure I need it.
   / $300 to load rear tires #30
Heat cycles in a tire? Compared to what, circulating in an engine?
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A55315)
2023 Kubota...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2018 FREIGHTLINER CASCADIA 126 SLEEPER (A57880)
2018 FREIGHTLINER...
2017 Ford F-250 Pickup Truck w/ Liftgate (A56858)
2017 Ford F-250...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
