$300 to load rear tires
   / $300 to load rear tires #11
I paid 250 for rimguard for my R4047. 110 gallons
   / $300 to load rear tires #13
Bob it is not that hard to do it yourself. There have been many treads on the forum explaining the process. I do recommend environmentally friendly anti-freeze for the sake of any animals if you get a leak.
MarkV
MarkV
Mark, I have thought about it and yes we do have animals.
   / $300 to load rear tires #15
Does anyone know the ratio for the antifreeze to water? This would be in Pa so it gets cold here.
Use the same amount as you would in the cooling system.
   / $300 to load rear tires #18
50/50 mix would be good to -34F. Do you need that much protection. For tires a little slush doesnt hurt a thing in tires. I would think that a 30% antifreeze solution would be plenty for tires.
You can look up the freezing point of different ratios on internet (lots of sites) and decide what you need to do. A device to fit on the garden hose to put in water is about $12 at NAPA maybe less at TSC.
One TBN poster described the easiest way to get antifreeze in the the tires is to put tractor on jack, lower the jack to flatten the tire slightly then with the tire filling gadget on the tire and end of hose in antifreeze bottle, jack the tractor up and the fluid will be drawn into the tire by vacuum. Repeat as needed to get all the antifreeze into the tire. Have the valve stem at top dead center for all filling. When you stop getting air out and water comes out instead, the tire is full. You will have to stop filling with water and bleed the air a few times to avoid overpressuring the tire when filling. I filled my Yanmar tires when I got it several year ago in about 5 minutes per tire after getting the blocks in place for the jacks that it. Total time was about an hour for all of it including swapping the tires from each side to widen the stance prior to filling with ballast. I did have a helper on this as I didnt want the tires to get away and lining up the lug bolts was much easier with a helper.
Check your pricing for the required amount of antifreeze and you can readily see how much your dealer is charging for labor. I wouldnt think more than 4 gallons per tire is required @ $10 or less per gallon.
   / $300 to load rear tires #19
Yea I have all of the stuff to load tires, done several with calcium but these are tubless tires so I want to go a different route. I will also be pricing the cost of the rimguard if it is within reason I'll get that instead. I just wasn't real sure on how much antifreeze I would need "yea I know I live in the cold I should know" 50/50 seemed a little strong to me and costly too it may have been less with rimguard at that mixture.
   / $300 to load rear tires #20
I am sure Gary's method would work. I was a bit to lazy for that and bought a $10 little pump that is run by an electric drill. The rest of it was done with the bleeder valve that Gary mentioned. I'd price the cost of your anti-freeze of choice and see if $300 makes it worth while.
MarkV
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
2012 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58017)
2012 FREIGHTLINER...
2022 JOHN DEERE 330G SKID STEER (A52705)
2022 JOHN DEERE...
