300 (1020) backhoe hydraulic problem Please help.
/ 300 (1020) backhoe hydraulic problem Please help. #1
300 Backhoe
Dillsboro, Indiana
Farmall, Deere
Hello
Just purchased a 300 backhoe. 3cyl gas. When starting the tractor,it will crank over fine then it acts like the hydraulic pressure builds, then the engine cranks very slow.The only way I can (sometimes) get it to start is to move the steering wheel left to right while cranking. If it does get started the steering column gets hot in a short amount of time. Could anyone recommend what I need to look for. Thank you for your help.
/ 300 (1020) backhoe hydraulic problem Please help. #2
I would suspect the steering valve first. The steering and brakes have priority over everything else on the tractor I should add. Just a hunch but I suspect the steering valve needs to be rebuilt.
/ 300 (1020) backhoe hydraulic problem Please help. #3
The steering and brakes have priority over everything else on the tractor I should add. .
jenkinsph
Your statement is true on Waterloo tractors of the same era but the priority valve on JD utility tractors has zero to do with providing trans pump oil to the brake valve reservoir. Yes priority valve on utility does give power steering priority oil.
/ 300 (1020) backhoe hydraulic problem Please help. #4
jenkinsph
You are right, I should have thought of that since my 820 didn't have power assist but the 4020 did if I remember correctly. Seems that below 1900 psi the priority valve closes off the other hydraulic functions and runs flow to the steering as a fail safe. I am going back to the mid 1970's so my memory may be lacking. At any rate what do you think about the steering valve being a prospect?
/ 300 (1020) backhoe hydraulic problem Please help. #5
I totally agree with you on the steering valve as needing seals replaced.
/ 300 (1020) backhoe hydraulic problem Please help. #6
Do you have all the the hyd valve levers in neutral when starting?
You could put a hyd gage in the IN port of the BH valve and see if there is any pressure at start up.
Recheck any QD's you might have.
Is the filter good?
2012 FORD SERVICE TRUCK (INOPERABLE) (A65643)
2012 FORD SERVICE...
2026 Deere 320P (A64126)
2026 Deere 320P...
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
Case IH 181 Rotary Hoe (A66408)
Case IH 181 Rotary...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
