3 year old 2021 TYM 474, wont turn over
   / 3 year old 2021 TYM 474, wont turn over #1
saxon11
Minnesota
TYM T474
This tractor has been great for me, and to my surprise tried to start it, and batties on, but no turn over. I troubleshoot, look in manual. Verified PTO is off. I'm on the seat. The brake it pushed. I even jumped the battery. Still nothing. What could I be missing here?
   / 3 year old 2021 TYM 474, wont turn over #2
Start by load testing the battery. I will emphasize LOAD TEST. Batteries can go bad and have voltage but still won’t start the tractor or even allow them to be jumped.
If the battery checks out look at a bad seat switch or other safety switch. Sometimes just jiggling things will make it start. Then check fuses.
   / 3 year old 2021 TYM 474, wont turn over #3
After you perform the steps above, remove and clean the high amperage connections at the battery, frame, and starter.
   / 3 year old 2021 TYM 474, wont turn over #4
If it is like my 574, there are 2 PTO switches that need to be off. The switch from off-manual-auto and the push button toggle that lights up when it's on.
Even if the switch is set to off, if you push the toggle, it will not work, even though it doesn't light up....ask me how I know!
I hope it is something this simple for you.
   / 3 year old 2021 TYM 474, wont turn over #5
There is also some large fuse blocks by the battery. Check make sure nothing happened to them?
2018 HINO 268  NON CDL 26FT BOX TRUCK (A52576)
2018 HINO 268 NON...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
AMADAS SPC-6 LOT NUMBER 257 (A53084)
AMADAS SPC-6 LOT...
198367 (A51243)
198367 (A51243)
2022 JOHN DEERE 331G LOT NUMBER 99 (A53084)
2022 JOHN DEERE...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
