3 year old 2021 TYM 474, wont turn over
   / 3 year old 2021 TYM 474, wont turn over #1
saxon11
Bronze Member
Minnesota
TYM T474
This tractor has been great for me, and to my surprise tried to start it, and batties on, but no turn over. I troubleshoot, look in manual. Verified PTO is off. I'm on the seat. The brake it pushed. I even jumped the battery. Still nothing. What could I be missing here?
   / 3 year old 2021 TYM 474, wont turn over #2
Start by load testing the battery. I will emphasize LOAD TEST. Batteries can go bad and have voltage but still won’t start the tractor or even allow them to be jumped.
If the battery checks out look at a bad seat switch or other safety switch. Sometimes just jiggling things will make it start. Then check fuses.
   / 3 year old 2021 TYM 474, wont turn over #3
After you perform the steps above, remove and clean the high amperage connections at the battery, frame, and starter.
   / 3 year old 2021 TYM 474, wont turn over #4
If it is like my 574, there are 2 PTO switches that need to be off. The switch from off-manual-auto and the push button toggle that lights up when it's on.
Even if the switch is set to off, if you push the toggle, it will not work, even though it doesn't light up....ask me how I know!
I hope it is something this simple for you.
   / 3 year old 2021 TYM 474, wont turn over #5
There is also some large fuse blocks by the battery. Check make sure nothing happened to them?
1998 Dodge (A50121)
1998 Dodge (A50121)
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2010 Ford F-150 XL (A50120)
2010 Ford F-150 XL...
14" Pipe Ditch Lift Pump (A50121)
14" Pipe Ditch...
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
Maletti BCV3180 (A50121)
Maletti BCV3180...
