3 pth snowblower
/ 3 pth snowblower #1
simonmeridew
Northeastern Vermont
Kubota L4400
Any recommendations for a 3 pth snowblower, rear mount, for my L4400 Kubota? Northern Vermont gets a lot of snow, for the last few years I push it around with my front end loader, but I'm thinking of upgrading. I don't have rear hydraulics on my tractor.
simonmeridew
/ 3 pth snowblower #2
I am considering a pull-type snowblower for my DK35 HST. I have an 800' driveway which I clear with a rear blade. But after making passes with the blade I have to make a pass with a walk-behind type snowblower to blow the snow into the field. Either that, or I have to make the final push of the snow into the ditch driving in reverse.
My dealer sells MK Martin blowers (Farm Equipment from M.K. Martin Enterprise) and I'll get a quote on the SB68 P/T (68") model. I'll also look for others before buying.
/ 3 pth snowblower #3
I've got the Kubota front mount blower, 72" wide. Since you have about the same power I would suggest you look for something over 6' wide if you have turns in your driveway, the 72" barely covers my tracks. I know others here can point to other brands that are as good as the Kubota (I believe they are made by RAD Tech out of Canada).
I don't think you'll need a hydraulic connection as I think you can get a manual chute rotator (or convert it to electric). If required you could extend the lines and use the connections from your FEL.
/ 3 pth snowblower #4
I would get a 3PH snow blower. A 3 pth probably wouldn't even fit.:D
Only kidding. Allied, Farm-King... your choices are endless.
/ 3 pth snowblower #5
I use a 74" Farmking on my L39. A rear facing 3 point blower is fine as long as you do not have too long a driveway or neck problems. I picked mine up used off Craigslist. I have a hydraulic chute which is nice. If you are going to get a 3 point blower, then I would recommend you consider adding a rear remote for chute control as well.
/ 3 pth snowblower #6
I have a 60" Meteor on my B2410 in 'the kingdom'.
I think you will find Meteor popular in the area, as Derby Equipment used to sell them.
I recall reading that the newer models seem to have more gearbox issues, though.
I would post a 'wtb' on Craigslist and see what responses you get. With the snow finally gone, the timing would be good.
/ 3 pth snowblower #7
I have a three point Kubota LA2674 snow blower. Built real good with grease able fittings on bearings, adjustable skis shoes and is real heavy duty. I have rear remotes on my 3540 Grand L so chute rotation is hydraulic, nice unit and It's built by RAD for Kubota, It's the right color of course.You could use the manual chute rotator is you do not want to add rear remotes, 74" is quite a nice pass and it will throw the snow quite far. For lighter snow I use a heavy duty back Blade a Land Pride, a 1572 when I had a B3200, but now a RB3584 for the Grand L. There are times that I also use the FEL especially when the snow is real wet, the 72" heavy duty bucket makes short work of heavy snow.As you can tell sometimes it depends on how much or how wet the snow is determines what attachment to use. We also receive much o snow here in up-state N.Y.I live in the country surrounded by 100 's of acres of corn fields, we do get lots of drifting of snow.
DevilDog
/ 3 pth snowblower #8
The Meteor blowers are the brand name for MK Martin blowers mentioned in my previous post.
I think another popular brand is Pronovost:
Pronovost Snowblowers
I think they are heavier-duty blowers than some others.
/ 3 pth snowblower #10
Ah snow blowers(which are actually snow casters) one of my favorote topics:
I have added a lot of material regarding snow casters here and on the plowsite forum describing the potential volumes removed per minute with any snow caster by measuring the size of the impeller housing and multiplying the volume converted to pounds (one cubic foot of snow wieghs 21 pounds per cubic foot or more depending on snowmelting (during daylight hours) and air temperature which adds to snow melt wieght.
Factors to consider in any purchase of a snow removal attachment:
A front mounted blower will-
a. cost more to purchase as it is "machine specific" to the individual machine it is mounted to and it becomes a permanent wedding year after year good or bad with this SPECIFIC tractor.
b. has more material to mount the snow caster to this specific tractor.
c. a front mounted snow caster has a sub frame that will attach to the belly of the tractor and the rear axle in most cases.
c1. the front mounted snow caster and mounting frame takes up a very substantial amount of usable space if stored indoors.
c2. The subframe mounted snow caster has been blamed for many hundreds of viscious attacks on ankles, shins, boots, which include tripping over the sub frame when it deliberately jumps in front of the offending body part(been there done that)
c3. promotes one to create and or expand ones vocabulary of curse words in english, french, german, and swedish languages among others.
c4. the cross augers and impeller are generally smaller in size than the rea mounts and less efficient in snow casting heavy snows due to energy losses from speed and torque loss.
d. reduces the amount clearance under the tractor in question (not good when stuck). been there done that with snow plows (same frames).
e. requires speed reduction from mid point P.T.O.,
resulting in power and fuel waste(in my opinion)
A rear mount snow caster will cost less as it does not require one to purchase a sub frame to mount it on any tractor.
The rear mount snow caster will move from machine to machine when trade in tim comes and will not lose value quickly like a front mounted snow caster.
You can purchase a wider snow caster in a rear mount and simply operate a little slower at high idle for the rear P.T.O., to clear a wider path all the time every time and spend less time snow cutting for the the small bits and widths that are left.
Personally I like the Pronovost snow casters but its a matter of preference and ones pocket book.
I would contact Ken Sweet as he is a sponsor of the forum here and ask him for a price on his product lines as he also ships from his facility as well.
/ 3 pth snowblower #11
I sure like my rear snowblower. I would go no other way.
Got mine at General Truck and Equipment Inc. Westminster Vermont.
Real friendly people and easy to deal with.
/ 3 pth snowblower #12
I just went through a Manitoba winter with my Buhler ( 60 inch on a BX 2200)
Total maintenance 1 shear bolt and a can of chain lube 1/2 tube of grease for the PTO shaft.
Only modification was the addition of a remote chute control (electric)
I'm impressed with the unit.
TGR
/ 3 pth snowblower #13
TGR
That a Farm King, I presume? Usually cheaper in Canada,too
/ 3 pth snowblower #14
64" Blizzard by RAD industries treated me right this past winter. Rear mount works for me, and manual chute was not a problem, It has a long linkage, I can reach it from the seat, no need to get off the tractor to adjust it. Clear about 1500' with it.
/ 3 pth snowblower #15
I have a 68" meteor pull type snowblower for my three point hitch and I do 1 mile of private road. I also have 7 driveways and all my neighbors love my work and are quite impressed with my machine. my tractor is an L2800 with a heated sims cab, couldn't do without it.
I have had this snowblower for 3 winters and have had to do some repair work to it but for all the work it has done I cant complain.
/ 3 pth snowblower #16
TGR
I also just went through a Manitoba winter using a 60" farm king blower on my bx2350. I find that the blower is way to heavy, the leveling adjustments are a total bear to get just right for blowing snow on a gravel driveway(the spring cleanup of gravel on the lawn has been a complete nightmare) and the 5/8" gap between the fan tips and the housing really cut down on the blowers efficiency not to mention make for a great place for rocks to jam.
Also if I accidentally lift it too high the pto shaft beats the crap out of the turnbuckle pins so all in all I find that it's over weight, over priced and under designed, it's also up for sale as I don't want to go through another winter pushing that blue beast into hard packed snow banks. But this is just my humble opinion.
/ 3 pth snowblower #17
Where were you earlier this last winter when I bought my brand new 60" Buhler? :eek: I think I'm just across the border from you and maybe could have saved a bit. :rolleyes: Oh well, too late now.
BTW, I love mine!
Joe
/ 3 pth snowblower #18
I have a Lorenz 3 point mounted snowblower with electric chute rotation on my L3540. I have nothing but good things to say about this blowers performance, design, and construction. I have only had it this one winter so I cannot comment on reliability yet, but I can say I did not have one single problem with it over the winter.
/ 3 pth snowblower #19
I would talk to your Kubota dealer about a Kubota blower. I have a Frontier and I think the Kubota blowers are made by the same company.
I would look at a 74" 3pt blower, possibly bigger for an L4400.??
I am totally satisfied with mine. It does a real nice job and you can stuff it full of snow and it just chugs it away...gone. Smooth and quiet operation, perfect for those quiet Vermont winter nights.
My neck was sore for a short period, then I felt fine for the rest of the winter. You get used to it.
What does your L4400 have for transmision...gear.?? My JD770 is gear and I was thrilled with the operation.:thumbsup:
/ 3 pth snowblower #20
Not to be completely off topic but I just sold my BX front mount and it was a gem. $$$ though.:(
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2026 Electric Tricycle (A64194)
2026 Electric...
20ft trailer (A61569)
2017 Ford F-150 Pickup Truck (A64556)
2017 Ford F-150...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2012 International 4300 Reefer Truck (A63689)
2012 International...
