3 pth raises self
/ 3 pth raises self #1
MaineGuy
Vassalboro, Maine
1981 Ford 1200
What are some causes for the 3 point hitch to lift while I'm mowing with a rear finish mower. I have to hold the hydraulics lever forward in the down position to keep the mower from lifting. What should I check?
Ford 1200 with 1025 hours. 45 hours since last full complete service.
Thanks for your help
David
/ 3 pth raises self #2
Look for a friction disk that needs to be adjusted to hold the control lever in position. Sounds like it is worn a bit and needs tightening.
/ 3 pth raises self
Thanks for putting me on the right track. I'll take a look at that tomorrow. It looks like there should be a cotter pin, adjusting nut and spring washer.
David
/ 3 pth raises self #4
Does this tractor have draft control? IF so you should disable it , or set it to it's hardest/deepest setting when using the mower. If it is enabled it could cause the mower to raise.
/ 3 pth raises self #5
How could it do that?
If something did cause enough compression (I can't imagine what) on the top link to cause the draft to lift the 3pt, then it would come back down as soon as that 'compression' was relieved.
I'm puzzled by this.
/ 3 pth raises self #6
Beenthere,,You are correct it should go back down after pressure is relieved but does not always work that way on the older tractors.I had a Massy TO30 that would lift all the way up when i hit a hole or went across a ditch causeing a load on the draft system. It still does it a little at times though paw in law has adjusted draft system.Perhaps a sticking relief system ???
/ 3 pth raises self #7
On my tractor seting the draft control to it's lowest (lightest) settings the 3PT will raise with nothing attached, and stay there!! I asked my dealer about this and he said that's the way they work.
/ 3 pth raises self
The tractor is not equiped with draft control. Thanks for your thoughts. I have adjusted the lever friction but haven't tested it yet. The lifting does seem to occur over uneven terrain as if the ground lifts the mower and the hydraulic pressure holds it up.
David
/ 3 pth raises self
Beenthere, I adjusted the friction and it took care of the problem.
Thanks for taking the time to help out.
David
New/Unused Wolverine 72in Quick Attach Tiller (A61166)
New/Unused...
2016 Chevrolet Silverado 1500 Pickup Truck (A61568)
2016 Chevrolet...
CORE CUT CC1200XL WALK-BEHIND SAW (A62129)
CORE CUT CC1200XL...
New/Unused IRMC Massage Chair (A61166)
New/Unused IRMC...
APPROX (14) 20'-35' HEAVY DUTY INSULATED PANELS (A62131)
APPROX (14)...
2018 Ford F-150 4x4 Pickup Truck (A61568)
2018 Ford F-150...
