3 pt Receiver Hitch attachment
   / 3 pt Receiver Hitch attachment #11
Ken, your hitch looks good. I think every tractor owner needs one if dealing with trailers on his property. I have about 6, one for about every need and find it much easier to move them around with the tractor, especially if doing work around my 5 acres. Cutting grass is easier when moving trailers with tractor.
I did not put safety chain hooks/rings on mine. Didn't see the need just working off road. The restraining chain sounds good if you are going to use it with dumping but most trailers have enough tongue weight not to need that either. I try to keep it simple.
I built my first one from scratch like you did, used 3" x 1/4" tubing. I have even moved small (12X 40) mobile homes with a 70 HP tractor and a 2 5/16 ball. I later built one that is lighter using a piece of 2 1/2" x 1/4" angle iron for the main spread then putting a 2" tubing upright and a mobile home spring hanger bracket (drilled out bigger) for the top link reciever bracket. Butt weld the reciever tube and weld on the lift arm pins, light weight but strong enough to move a loaded 5' x 10' trailer.
A friend owns a welding shop and gets reciever style hitches from a car dealer that takes them off prior to sending cars/trucks to auction. He sells them to me for 5 bucks each, cheaper than the factory reciever tube, add pins, upright and bracket for top link and in 30 min I can have a new hitch. It sure beats the 150.00 or so they sell for.
After using it for just trailers, I built 3 rakes, (root rake using teeth from a box blade, hay rake from old mule drawn rake and section harrow, bought teeth for 59 cents each) that attatch to tractor using my "reese hitch". I already bought the teeth to build a leaf/pinestraw rake using hay rake teeth and I will use the reciever hitch for that as well. No need to build the 3ph on the rake, just slide it in the reciever. Another simple build. I made an upright boom pole leaning about 30 degrees out, 2' long, to drag trees with, shorter so it will pick up more weight, a fence wire bracket to hold a roll of wire, use it with a pickup "carry all", and even slid a hitch in it , backed up to my yanmar that had been sitting and pulled it in the shop like a wrecker using my Ferguson as the towing tractor. The front weight bracket served perfect as my front hitch to pick up with a trailer ball. I have a rig built to carry my acetylene torch with a boom truck (no wheels) and plan on adding a piece of tubing to it to carry my torch from same hitch with tractor. No forks yet but thay are coming.
The little reciever hitch you have built will work for all kinds of applications. Just slide in a piece of tubing and build it from there.
The only thing I did to my heavy one that you haven't added to yours was a piece of 2" flat bar about a foot long standing straight up from the reciever tube to the top link upright. I thought it would brace the two against each other. Must have worked, mobile homes did not bend it. That brace was brought out about 3 inches and leaned into upright.
Also, I use a 1 7/8 ball on the tractor. Most of my hitches are 2" or 2 5/16. Smaller ball allows tractor to pull ball out of hitch and I never have to get off of tractor unless moving a block under jack.
   / 3 pt Receiver Hitch attachment #12
They are 1 1/2 Outside square stock, Is about 3/8 wall. Only use to move small pallets around, as my tractor won't pickup large pallets. lifting weight at end of drawbars is about 1600 LBS so will pick up about 1000 LBS. Is still handy to move things around like small buildings on skids just stick under one end wrap chain around and go.
   / 3 pt Receiver Hitch attachment #13
I finally found the round tuit I've been looking for and built this piece. I've been engineering the design in the back recesses of the brain for the past year. Started last Friday night and finished afternoon of the next day. Now to clean and paint.
The tubing is receiver hitch outer tubing purchased from Pacific Recycling here in Boise. The lift pin brackets are 4" X 3/8" plate. The receiver tube was purchased and welded to the horizontal cross member. With gussets all around for the upright and the receiver tube, I think this will be more than sufficient to move my boat and the 16' trailer I use to haul my Kubota BX 24. The stinger was on sale at Harbor Freight, and with the 3 ball sizes and hook for $26.00, the picture is complete.
Welcome to TBN.
That is a very nice job you done there, i like how you braced it and that is some nice welds.
You are like me, every time i build or weld something i make it extra strong, you could turn that into a logging hitch.
Thanks for sharing____very nice work!
_______________________________
   / 3 pt Receiver Hitch attachment #14
Very nice!
here is a caveat for everyone- last week I bought a 12" receiver tube made by Reese from Tractor Supply. Got it all fabbed up into a hitch for my fathers motorhome. THEN I discovered the tube is made incorrectly and is a hair too small to accept many 2" drawbars.:mad: The 5/8 hole for the pin is also too tight, I'm betting they've gone Chinese on sourcing these now.... An email to their customer service (HAH) has gone unanswered for a week now...
Moral of the story, check inside a receiver tube before welding it up in a project...the red faced ":mad:" doesn't begin to address my anger at Reese.
Catching up a bit here after a busy weekend. Thank you all for the comments, feedback and support. Over the weekend I welded on a ring to the front of the hitch to which I can attach a limiting chain. Still haven't figured out exactly how I will do the safety chain attachment, but I am going to add that feature as well.
Going out of town for most of this week, I hate to be gone from the Rancho, but them's the breaks I guess.
Ken
   / 3 pt Receiver Hitch attachment #16
Check out my receiver hitch. Just click the link below.
Scarlo101,
Nicely done! Looks like you've built a couple of different versions of the front hitch?
How much vertical travel do you get with the front hitch?
Ken
Waking this thread back up to post pics of the finished product.
Following feedback from forum members, I added a D-ring for a hold down chain-to-the-drawbar to keep the thing from rising unexpectedly. I decided not to include rings for safety chains as I'll just be using this to move my boat and landscape trailer in and out of parking places, no road travel.
I had to wait a while for the temps to warm up enough to paint. Soooo, after 2 primer coats and some number of color coats (Kubota Bright Orange), here's the final deal, bright and shiny to match the tractor (BX24).
   / 3 pt Receiver Hitch attachment #19
Nice. Will you build me one too? :D
   / 3 pt Receiver Hitch attachment #20
I like the pins facing inward. On my brush hog I changed them to face that was as brush would unsnap the lynch pins and let the drawbar loose. With them inward and the sway links tightened even without lynch pins it won't get free.
Geismar powered by Stihl (A56435)
Geismar powered by...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
Pickup Instructions (A55272)
Pickup...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
2015 Ford Transit 150 Cargo Van (A56858)
2015 Ford Transit...
