3 pt quick attach
/ 3 pt quick attach #1
BoFuller
Arizona
2008 Kubota L3400
I have a L3400 and have a box scraper and a post hole digger and I just got a rear blade. I would like a quick attach setup. Will any accommodate the post hole digger or will they only work with the scraper and blade? How about choices? The dealer wants $500 for a Land Pride model. Will others work as well?
/ 3 pt quick attach #2
I have an "el cheapo" from Harbor Freight -- less than $100 -- others here on tbn have better but you can bet we all agree -- QAs are great. My post hole digger does not work with the QA but everything else I have does. bush hog, box blade, grader blade, landscape rake, and carry-all. You can spend as much or as little as you want -- how fancy do you want to get -- there are a large variety of makes & styles to choose from. All you can do is search and decide what works best for you. You can try to do a search here on the forums for "quick attach" .....I'd say be ready for some reading....;)
/ 3 pt quick attach #3
There are a lot of options out there. I run John Deere imatch's and love them. All of my implements fit them and the change process is quick and easy. The only available QA that i think will work for your PHD as well is Pat's QA which only uses the lower links on your three point (you have to manually hook up the top link).
/ 3 pt quick attach #4
A post hole digger does not use a toplink so it is not quick hitch compatible. I have a harbor freight quick hitch and I love it. The lift arm pins were to small so I drilled them out to 7/8. I looked at a QH at TSC Sunday and it did not look better than my harbor freight QH. When you use a QH you have to use bushings for the top link and lift arms. You should also recheck your pto shaft length.
/ 3 pt quick attach #5
I have a L3400, and a QH. But I just bought a Pat's system, I like it better.
/ 3 pt quick attach #6
Bo,
The Landpride QH is a good unit. The only thing that I would suggest would be to get the longer lower bushings as the ones that come with it are a little too short. I just set one up for a customer last week for a cutter, blade, and tiller. I think that the short bushings allow too much "sloop". I work for a dealer in Cottonwood and we have a QH sitting in the store. Send me a PM and I'll give you my number.
/ 3 pt quick attach
Thanks for all the input. I still haven't made up my mind though.
1996 Aspen T/A Pump Trailer (A64194)
1996 Aspen T/A...
2013 Ford Taurus AWD Sedan (A64557)
2013 Ford Taurus...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2005 Airman PDS185S Towable Air Compressor (A64194)
2005 Airman...
2006 Snorkel AB50J 50ft 4x4 Articulating Boom Lift (A64553)
2006 Snorkel AB50J...
213141 (A64276)
213141 (A64276)
