3-Point Hitch 3 pt pulse
/ 3 pt pulse #1
okietractor
Tulsa, OK
Yanmar 1610 & Century C47L w/50 HL FEL
The 3 pt lift on my Century 4720 pulses when carrying a load. It acts like it leaks off pressure and then compensates which causes it to jump up and down 1-1 1/2". Is there a pressure adjustment to look for or a bad seal maybe? It seems worse when using the FEL while the 3 pt is carrying something.
/ 3 pt pulse #2
It sounds like the O ring on the hydraulic piston is shot.
Branson makes a kit to repair it.
/ 3 pt pulse #3
Mine did some thing similar, turned out the filter needed to be replaced, use OEM filters, I had your problem with the aftermarket filters.
PAIR OF TRACTOR TIRES AND RIMS (A67714)
PAIR OF TRACTOR...
2019 KENWORTH T880 TRI-DRIVE HYDROVAC TRK (A67714)
2019 KENWORTH T880...
2020 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2020 INTERNATIONAL...
335 GAL WATER TANK (A68842)
335 GAL WATER TANK...
2019 FREIGHTLINER M2 4X2 S/A 26FT BOX TRUCK (A69167)
2019 FREIGHTLINER...
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
