3-Point Hitch 3 pt pulse
/ 3 pt pulse #1
okietractor
Tulsa, OK
Yanmar 1610 & Century C47L w/50 HL FEL
The 3 pt lift on my Century 4720 pulses when carrying a load. It acts like it leaks off pressure and then compensates which causes it to jump up and down 1-1 1/2". Is there a pressure adjustment to look for or a bad seal maybe? It seems worse when using the FEL while the 3 pt is carrying something.
/ 3 pt pulse #2
It sounds like the O ring on the hydraulic piston is shot.
Branson makes a kit to repair it.
/ 3 pt pulse #3
Mine did some thing similar, turned out the filter needed to be replaced, use OEM filters, I had your problem with the aftermarket filters.
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
1024 (A63111)
1024 (A63111)
CAT R450/D9H Ripper Teeth (8) (A68134)
CAT R450/D9H...
2014 MACK PINNACLE CHU613 (A68134)
2014 MACK PINNACLE...
2015 CATERPILLAR D6T LGP HIGH TRACK CRAWLER DOZER (A65056)
2015 CATERPILLAR...
(INOP) LAYMOR SM300 RIDE-ON SWEEPER (A65054)
(INOP) LAYMOR...
