3-Point Hitch 3 pt pulse
   / 3 pt pulse #1
okietractor
Tulsa, OK
Yanmar 1610 & Century C47L w/50 HL FEL
The 3 pt lift on my Century 4720 pulses when carrying a load. It acts like it leaks off pressure and then compensates which causes it to jump up and down 1-1 1/2". Is there a pressure adjustment to look for or a bad seal maybe? It seems worse when using the FEL while the 3 pt is carrying something.
   / 3 pt pulse #2
It sounds like the O ring on the hydraulic piston is shot.
Branson makes a kit to repair it.
   / 3 pt pulse #3
Mine did some thing similar, turned out the filter needed to be replaced, use OEM filters, I had your problem with the aftermarket filters.
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
Quick Hitch Skid Steer Attachment (A51691)
Quick Hitch Skid...
19?? Asphalt Roller (A52377)
19?? Asphalt...
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
