3-Point Hitch 3 pt not lifting?
/ 3 pt not lifting? #1
RHemmer
Independence Minnesota
Kubota b2400
I own a 1997 Kubota b2400 and was plowing snow this afternoon when the 3pt stopped lifting? I checked the valve that controls the rate of decent but that is fine. No growling noise from valve been worked.... just silence. I can manually move the arms by hand. Anybody got a idea where to start tracking this problem down?
Thanks in advance
/ 3 pt not lifting? #2
Did it slow down or did it just quit?
Any different noises, momentarily?
Your blade is on the three point hitch??
/ 3 pt not lifting?
No slowing down that I am aware of, and nothing with any different sounds. It is a back blade off the 3pt. The level of fluid was check and changed with in the last 2 hrs of tractor operation. This model tractor is hydrostatic tranny and that works fine. Thanks for your reply.
/ 3 pt not lifting? #4
Sounds like your lever is in the full down position (float). perhaps the lever has come loose at the transmission connection. Looks like it's pinned or set screwed from what I can see on mine..
/ 3 pt not lifting? #5
Hmmmm, "fluid was changed" 2 hours prior of having a problem
Could the strainer screen be clogged? Could there be some sort of air bubble in the system? I thought u had to cycle the three point lever several times to bleed the system after changing hyd fluid??
/ 3 pt not lifting?
When I changed the fluid I did take out and clean the screen,it was pretty dirty. I have used the 3 pt several times prior this happening, worked perfect until this. I am going to double check that a pin/set screw hasnt come loose on the lever. Thanks for your input!!
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
KUBOTA M8560 TRACTOR (A64277)
KUBOTA M8560...
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
John Deere MX8 3-Pt 8' Rotary Mower (A66285)
John Deere MX8...
20 Yard Roll Off Dumpster (A65579)
20 Yard Roll Off...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
