3 pt multi purpose bar
/ 3 pt multi purpose bar #21
I think this might work
Now some grinding and paint
A good start. Best to complete the box tho - by closing the "c" with a plate from the main box tube out to near the pin. Open sections twist rather easily.
larry
/ 3 pt multi purpose bar #22
Just curious if youve got a thought on how to keep it from rising up? On the one I made, I use a chain that attaches to the lower fixed draw bar, and have a grab hook welded to the 'attachment' so its adjustatble.Then when I set the hight of the hitch U put the chain over the grab hook and ever so slightly raise the hitch to put tension onto the chain. It makes for a sturdy hitch. Other wise the attachment can raise up at will.
BTW Great looking job
/ 3 pt multi purpose bar #23
Nice build, I built something very similar, hooks and hitch, comes in VERY handy.
/ 3 pt multi purpose bar #24
Had someone else tell me to run a brace from the top by the gooseneck hitch to where the it connected to the bottom links? Thoughts
I added some angle braces to mine. Does it really need it?? Don't know, but it surely can't hurt! :thumbsup:
Well I was able to try it this weekend. Worked pretty darn good for moving a pretty big log.
Giyi DHC Mini Quick Attach Forks (A60463)
Giyi DHC Mini...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 FREIGHTLINER M2 4X2 26FT CDL REQUIRED BOX TRUCK (A59906)
2019 FREIGHTLINER...
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
1990 TRAILMASTER CRUDE TRAILER (A60736)
1990 TRAILMASTER...
Freightliner Columbia (A61307)
Freightliner...
