3-pt Hitch Log Splitter or Gas standalone?
   / 3-pt Hitch Log Splitter or Gas standalone? #71
I debated the same thing last fall after installing an outside furnace. Decided to go with the 3 point hitch model. Bought a 16 ton Ramsplitter for half of what the other type would have cost. Been very pleased with the 3 point hitch model. Haven't found anything that was too tough for it. I usually run my tractor at about 1200 rpm.
WOULD RUN A 200$ MOTOR or a 10000$ tractor
   / 3-pt Hitch Log Splitter or Gas standalone? #72
nice rig
   / 3-pt Hitch Log Splitter or Gas standalone? #73
I favor the stand-along with an engine. I use the tractor FEL to lift logs onto the splitter and other moving. Can't do that if the splitter is attached to the 3 point.
   / 3-pt Hitch Log Splitter or Gas standalone? #74
I have one of those splitters with the two stage and spitting with it is sooo slow. I got it a trade and it is new. I made my own several years back and initialy ran it off the pto with a very large pump off a piece of logging equipment. Since then I put an engine on it and made it self contained. I still move it on the 3pt, and it works well. I can pick up a round as it has a 10ft boom with a 8000lb hyd winch. Largest I have split was about 6ft dia. The knife is a T and it takes two pieces off the bottom of the block each push. I just let the block down as I take them off and rotate the block as needed with tongs. For you home builders this really puts out the wood. I made it in the early 80's and is still there when I need it.
   / 3-pt Hitch Log Splitter or Gas standalone? #75
We've been over this a few times. Since I expect my tractor to outlive me, running the tractor is the obvious choice because it reduces overall maintenance effort and storage space. A few hundred hours at constant RPM will have no measurable impact on a small diesel engine. A wood splitter doesn't require use of the drive train which is probably the limiting factor on most compact tractors.
   / 3-pt Hitch Log Splitter or Gas standalone? #76
My tractor hyd. Line are full and the wrong size so I use a gas one.
2012 Ford Expedition 4x4 SUV (A56859)
2012 Ford...
2017 VOLVO VNL TANDEM AXLE SLEEPER (A58017)
2017 VOLVO VNL...
2004 DITCH WITCH 3700 RIDE ON TRENCHER (A52709)
2004 DITCH WITCH...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
2015 SKY TRAK 6036 TELEHANDLER (A58018)
2015 SKY TRAK 6036...
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
