3-pt Hitch Log Splitter or Gas standalone?
   / 3-pt Hitch Log Splitter or Gas standalone? #71
I debated the same thing last fall after installing an outside furnace. Decided to go with the 3 point hitch model. Bought a 16 ton Ramsplitter for half of what the other type would have cost. Been very pleased with the 3 point hitch model. Haven't found anything that was too tough for it. I usually run my tractor at about 1200 rpm.
WOULD RUN A 200$ MOTOR or a 10000$ tractor
   / 3-pt Hitch Log Splitter or Gas standalone? #72
nice rig
   / 3-pt Hitch Log Splitter or Gas standalone? #73
I favor the stand-along with an engine. I use the tractor FEL to lift logs onto the splitter and other moving. Can't do that if the splitter is attached to the 3 point.
   / 3-pt Hitch Log Splitter or Gas standalone? #74
I have one of those splitters with the two stage and spitting with it is sooo slow. I got it a trade and it is new. I made my own several years back and initialy ran it off the pto with a very large pump off a piece of logging equipment. Since then I put an engine on it and made it self contained. I still move it on the 3pt, and it works well. I can pick up a round as it has a 10ft boom with a 8000lb hyd winch. Largest I have split was about 6ft dia. The knife is a T and it takes two pieces off the bottom of the block each push. I just let the block down as I take them off and rotate the block as needed with tongs. For you home builders this really puts out the wood. I made it in the early 80's and is still there when I need it.
   / 3-pt Hitch Log Splitter or Gas standalone? #75
We've been over this a few times. Since I expect my tractor to outlive me, running the tractor is the obvious choice because it reduces overall maintenance effort and storage space. A few hundred hours at constant RPM will have no measurable impact on a small diesel engine. A wood splitter doesn't require use of the drive train which is probably the limiting factor on most compact tractors.
   / 3-pt Hitch Log Splitter or Gas standalone? #76
My tractor hyd. Line are full and the wrong size so I use a gas one.
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2018 JOHN DEERE 60G EXCAVATOR (A52709)
2018 JOHN DEERE...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
