3 pt ballast build
/ 3 pt ballast build #1
erparis
muskegon michigan
Bobcat CT 35
Have a Bobcat CT 335 with FEL. Definitely needs a weight on rear for grapple use. I have found a scrap piece of heavy wall tubing that I think will work very well. It is 24" OD x 19 1/2" ID x 17 1/2" long. So weighs in the 700# range. I plan on plasma cutting 3/4" plates to weld in each end. I will drill the center of each plate for the lower link pins of the 3pt hitch arms. This will get me in the 800 # range. 12" above the arms in lowest postion, 12" below the arms just off the ground. I think this will give me the greatest VCG advantage.
Is there any need to fit a clevis for the upper link arm? Anything I have missed on htis concept?
Thanks, Richard
/ 3 pt ballast build #2
I'm not an expert...I was thinking so you will drill the plates and the drilled holes will be axially inline with the center of your heavy pipe? If so, the only thing I could see in respect to not using a top link would be that the drum will want to rotate from time to time and it could wear the pins out faster. Easy fix if it does start to happen though. Where did you ever get a pipe that heavy?
Correct. Helps to work in a shipyard that has excess heavy material.
Richard
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
CHEVY 4X4 DUALLY TRUCK BED (A65643)
CHEVY 4X4 DUALLY...
2007 KENWORTH T800 TRI/A ROLLOFF TRUCK (A59914)
2007 KENWORTH T800...
Metal Mailbox (A64127)
2023 FORD  TRANSIT T250 CARGO VAN (A59914)
2023 FORD TRANSIT...
HD Running Gear (A66408)
HD Running Gear...
