3 Pt. Backhoe
   / 3 Pt. Backhoe #21
I picked up a 757 a few years ago from a TC40. Came with the subframe, but no mounts or brackets, nothing extra. Took a bunch of pictures of the original parts on the guys TC and fabricated up quick mounts for my old 1966 3400. Ended up with a great setup that works well and is real tough too! Sub frame is the way to go!
   / 3 Pt. Backhoe #22
Glad everything worked out for you :) . Think You will be happy with the set up and " Feel " since it is more attached to entire tractor .
Fred H.
   / 3 Pt. Backhoe
Well, my Liberty backhoe finally arrived, about 6 weeks later than promised. I uncrated it Saturday and hooked it up off my 3 pt. Did a 100 ft. ditch Sunday and it runs well. Now I'm going to dis connect it and put my subframe on and figure what kind of brackets I need. If I set this down with bucket and outriggers extended will it set there okay or do I need to make some kind of rack?
   / 3 Pt. Backhoe #24
Should sit there fine presuming that the liberty has a pin to prevent the boom/dipper from moving from cylinder bleed down when being stored
   / 3 Pt. Backhoe
Yes, it does have a pin for the boom, I had not thought of that. Thank You!
Nissan Forklift (A55973)
Nissan Forklift...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
Pines 1400 Tubing Pipe Structural Bender (A59213)
Pines 1400 Tubing...
2001 Ford F-550 (A56858)
2001 Ford F-550...
2019 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A58018)
2019 INTERNATIONAL...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
