Backhoe 3 pt backhoe
/ 3 pt backhoe #1
heehaw
russellville, arkansas
Kubota M4900, B7510 and RTV
i am really wanting a 3 pt backhoe to put on my 50hp kubota: or maybe the 21hp one?? haven't really decided that part yet: but i keep reading things about people "breaking the tractor" using these when the tractor doesn't have a "frame?". i don't understand? can someone tell me how this happens, other than puttin the backhoe thats for the 50hp on the 21hp tractor?
thanks
heehaw
/ 3 pt backhoe #2
Instead of mounting on the 3 pt , It mounts under the tractor distributing the weight across the tractor
Sub frame on right that mount to the back of the backhoe
/ 3 pt backhoe #3
thanks
heehaw
How ya doin heehaw?
I bought one of those taylor way 766 BH's early this year.. hooked it up 3pt and gave it a little stretch and moved it around to see what reaction the tractor had......very sloppy on my 24 hp tractor.. so made a subframe.......................................................................................................I'm sure you've checked the other threads concerning 3pt vs subframe so nothing earth shaking to add, you have more tractor knowledge than I do...:eek: ... but I think a big 50hp tractor should have no problem with a small 3pt hoe.
No one on tnb saying "they" broke a tractor with a 3pt hoe.. some 2nd-3rd hand stories, which may be true. Some people with hefty tractors happy with 3pt set-up though. Many more cautioning against it, With my experience with using it "with" the subframe I believe I'm saving the tractor some wear and tear.
/ 3 pt backhoe #4
Tim, that's a great idea --- modify the hoe to work as a subframe unit! Sure would like to see a couple (OK, 4-5..) pictures of how/what you did.
Thanks,
AKfish
/ 3 pt backhoe
i'm pretty "build it" shortchanged: but would also like to see how you came up with the subframe etc.
thanks
heehaw
/ 3 pt backhoe #7
HeeHaw,
Why a 3pt hoe? The 50 hp kubota tractor should have sub-frame hoe's from Kubota, Woods, bradco and other available. Or are you just looking to spend minimum $ on a very minimum hoe?
Mostly, you get what you pay for with backhoes. There may be some imports that are better than others - I don't know.
Good luck
jb
/ 3 pt backhoe #8
I recently put a Woods BH on my GC2300 adding the subframe to handle it. I considered a 3pt BH but in discussing this with my dealer, he said the subcuts (which I would suspect your 21hp is) are really not up to the task of the 3pt BH because you are hanging too much weight too far back.
I thought the 3pt would be easier to deal with because I wouldn't need to get the 3pt arms out of the way (another issue with subcuts because the BH should be up tight against the main frame).
With your 50hp you should be able to use either type BH and still keep the 3pt in place.
/ 3 pt backhoe #9
Thanks,
AKfish
morning AK will get some pics later for you. I hadn't done a heavy fab for many years and every connection I made would need tweaking and grinding, the hardest was drilling the many holes without buying some super heavy duty drill.. when I pre-drilled on the press and then welded, the twisting forces would misalign the holes..all my talents are marginal.:eek: ..Drilling through thick steel was tiring with my light weight Dewalt...The frame works, but takes some doing to line up for mounting..taking it off is not so bad..If I was doing it now I would make some changes for sure...
/ 3 pt backhoe #10
I hear you john: more money often means better equiptment.. however in my case, I didn't have more money. I spent 3700 on hoe with pump, spent a couple hundred on metal and welding rod and graded hardware. Spending 6-7k for a woods, bradco, etc. would spend more than budget allows. I now have a fully fuctional hoe that does what I need it to for 2-3k less...( I may be off on cost of other hoes with frames slightly ) With 1k ( I did not spent on BH ) I bought a used 3 1/2 ton rated trailer.
The ability to make most repairs myself makes spending more worth less. If I had to rely on tractor mechanics I think paying a premium for premium would be worth more..if ya follow my reasoning... so if heehaw wants to save money on equiptment all things should be considered...I still think a small 3pt hoe on his 50hp wouldn't hurt it, but I wouldn't make any promises ...
/ 3 pt backhoe #11
Having the tools, time, talent and will to git 'er done - can save a ton of money.
jb
/ 3 pt backhoe #12
heehaw, from reading TBN I was a little hesitant about TPH hoes before I actually used one and can only comment on what I have experience with (see sig). I personally would not hesitate to buy another one just like it. There is no dought in my mind that a sub framed hoe is a better all around way to go. However, IMHO an individual, especially knowing the remote possability exists, would have to exibit a mental deficiency to do damage to their person or the tractor. Keep in mind I am only commenting on Kubota recommended "matched" hoe and tractor and Kubota recommended mounting.
irwin, I was literally hours away from purchasing a hoe like yours and having it freighted to the west coast when I ran across my used BL4690 on craigslist. Still wonder about the Taylor Way though... seemed like a really decent hoe at the time.
/ 3 pt backhoe #13
If ya got a hoe in good shape for a good price you're ahead. Must be some good deals that never make it further then a couple miles through a small ad in the local paper .. I think about all the new backhoes bought in the last 5 years or so, used for a year (maybe) then they sit in a shed for years... As long as it was protected somewhat it would be new to me..I looked for 6 months before I bought the TW.
I did have one issue with it, but $40.00 and a little time. This hoe is very solid and strong, it's been helping me a lot, never woulda been able to dig the holes I"ve dug by hand. Got a bad back and I'm too old for heavy shovel work...:( ....., and neighborhood kids don't like to work for money, guess they only need to hold a hand out and it gets filled with twenties..:rolleyes:
/ 3 pt backhoe #14
Thanks,
AKfish
built in several stages !st: mount to tractor at FEL mount and at rear where ROPS is bolted to, also at drawbar mount, 4" x 3/8 channel / 4" x 3/8" bar / 4 x 3/8 angle ...2nd: at hoe piece of 4" channel, some of the angle, and ...3rd:welded those 2 sections together, 4th: (not shown ) 3 x 1/2 bar to angle up to top hoe mount where a heavy 1" id tube welded to bar then welded to 3 x 1/2 bar
Ok AK here's some in process pic's
...........................I'll get a finished product shapshot later to show how I secured the top of hoe to the frame.. for that space was tight, had to make sure the pump could be put on and taken off ..I know it's not pretty, just functional. will go for pretty next time..:D .
/ 3 pt backhoe #15
Thanks for the pics, Tim. (I learn best if I can see it...) Looks like a thing of beauty to me! Great job!
If I kinda understand the process --- you built the subframe from the FEL back to the drawbar and then welded the the hoe frame into a single mount. Used some beefy steel, too!
It'd be great to see how it ties into the top-link on the 3-pt, too.
So, when you put the hoe on --- you bolt it into the FEL up front (X number of 1/2"), and then 4-1/2" bolts at the drawbar and hook the PTO pump up. Is that the method?
Of course, then a big pin or bolt on the top-link, yes?
The construction and material dimensions is real similar to my JD 8A backhoe.
I get a real kick out of seeing a little "ingenuity" and some sweat equity! With a fixed, retirement income --- I'm gonna have to work more on sweat equity and less on a payment book with the bank!
AKfish
/ 3 pt backhoe #16
:D
AKfish
Thats a big yes AK, sorry about not posting that last final pic showing it mounted at bh top pin. Seems I can't keep up with the "much" better-half's horse home needs-some day will have fences up, lane from barn to pasture cleared (including open a stonewall for walk-through), barn completed, walk around leveled, and haven't started on my own list yet.. Nothing wrong with having some projects...:D I only have weekends to whittle away at job lists, so try to plan for biggest bite per...
/ 3 pt backhoe #17
Margaret Thatcher did a pretty good job as well i think... ;)
Just a general tip:
Using the phone for an hour or 3, can save you many many bucks.. sometimes you can find double the quality fo half the price if you take a good look around...
I allways keep in mind that the money a manufacturer spends on advertising, is calculated into the price of a product.... From this point of view, it explains why using the phone to do some "reversed advertising" can give you more for less.... ;)
/ 3 pt backhoe #18
irwin said:
:D
I'm still waiting for the final pic showing it mounted :) .
/ 3 pt backhoe #19
ooooops, I knew there was something I was forgetting..:eek: Will write myself a note right NOW.:D :D
Amazing how life gets in the way ain't it Seon..
Here's a couple, just pretend you can see how the subframe is attached.;)
/ 3 pt backhoe #20
Okay Seon and AK, finally got it..........here's the front mount....
.and a shot over rear between em.................
..and top mount on hoe. ( When I'm down with this round of backhoe work I'll take it off and sandblast it for painting...no really I will ). Used a very thick tube steel welded to 3/8" bar cut to fit then the 1/2" bar angled to frame, secured with lot's of welding...
I had to buy a ROPS extension, my head wouldn't fit...:D ( course now I'll have to paint the tractor to match the ROPS extension)
SEARS ELECTRIC AIR COMPRESSOR (A64276)
SEARS ELECTRIC AIR...
2002 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2002 FORD F150...
2011 SPM SAFETY IRON 100 BBL 10 PUMP MANIFOLD TRAILER (A67714)
2011 SPM SAFETY...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
GENERAC MOBILE PRODUCTS  MAGNUM LIGHT/WATER PLANT (INOPERABLE) (A67714)
GENERAC MOBILE...
