3 pt attachments in hitch hole?
   / 3 pt attachments in hitch hole? #1
RCT
Raleigh, NC
Cub Cadet 2138
I would like to get a box blade for my 2138, but I don't want to go through the extra expense of a three point hitch. Won't it just hook up to the hitch hole? I know I won't be able to lift it without the 3pt hitch, but I can just haul it where I need it with the wagon and then use it there.
   / 3 pt attachments in hitch hole? #2
It wont track right without some sort of arms to control it. It will just swing from side to side when ever it wants to.
   / 3 pt attachments in hitch hole? #3
But don't give up, they have implements made for your single hole hitch.
Search and ye shall find.
   / 3 pt attachments in hitch hole? #4
RCT -
I'm in the same boat with no 3 pt. in the rear on my 3184. If you find some items, as Willl says can be done, please post them. I'd like to have a look and have yet to get results from my search.
Cheers!
Kent
   / 3 pt attachments in hitch hole? #5
I have found a Box 'Scraper' that can be used with a regular hitch
from Farmstar. If you are interested in this you can find it at this link...
You might try looking for the box 'blade' under ATV attachments via
a google search. I have often had better luck finding attachments via
this search method than lawn tractor, etc.
ATV or Garden Tractor Attachments
   / 3 pt attachments in hitch hole? #6
   / 3 pt attachments in hitch hole? #7
Electric... hmmm - very interesting, 1olddawg. Any specs on it, or pics of the controls, you can share?
Cheers!
Kent
   / 3 pt attachments in hitch hole? #8
The control is a simple center off spring return 2 pole toggle switch. I mounted it on the right side of my control panel. It comes with the hitch assembly. The way mine is mounted (center top of the rear plate) the actuator angel is 42deg up to 60deg down. Total lift is 8". The actuator is rated for 500 lbs. Never tested it at that weight, so I can't swear that is fact!! 1OD
   / 3 pt attachments in hitch hole? #9
Cool... you found it on eBay; any idea if tractor / farm stores would sell the same thing?
   / 3 pt attachments in hitch hole? #10
Check out johnnyproducts.com. They have a new model that really looks good...I like the fact that the lift is located in the center, un-like some of the side mounts which will bend it's own frame!!! Here's the link:
Cub Cadet Sleeve Hitch
1OD
1995 HESSE CORPORATION BEVERAGE TRAILER (A53843)
1995 HESSE...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2007 FELLA SM350 3 PT DISC MOWER (A53473)
2007 FELLA SM350 3...
2003 Chevrolet Silverado 3500 Crew Cab Pickup Truck with Gooseneck Hitch (A51692)
2003 Chevrolet...
