3 point
   / 3 point #1
cheesehead22
Ferguson T20
3 point will not go down /only up when engaged after being in storage all winter. fluid milky.
   / 3 point
Sorry I should have added its on a Ferguson T 20.
   / 3 point #4
Hi, and welcome to TBN. The three point goes up under hydraulic pressure. It goes down from gravity. There is usually a valve centered on the operator's seat between your feet. It must be opened to lower the three point. How far it is open adjusts the lowering speed. If the fluid is milky it has probably taken on some water.
   / 3 point #5
An old to20 won't have a drop speed knob.
Try putting some weight on the arms. Stand on them or something.
That or the draft control rod/spring may be frozen preventing lowering. Try w couple taps with a hammer
2011 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52577)
2011 INTERNATIONAL...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
2013 FORD F-650 ROUSTABOUT (INOPERABLE) (A52472)
2013 FORD F-650...
2007 DOOSAN G80 GENERATOR (A52472)
2007 DOOSAN G80...
48" Pallet Forks  (A52384)
48" Pallet Forks...
SORKO MC19-10 LOT NUMBER 149 (A53084)
SORKO MC19-10 LOT...
