Chipper 3 point wood chippers
   / 3 point wood chippers #1
waycoolmarine
illinois
john deere /kubota
can we do this 1 more time ? I have found a bunch of old threads ,nothing real current . I have got lots of good input from the old threads but can not decide . I know I want 8" hydro feed and im between woodmax wm-8h [ very popular ] and woodlandmills wc88 [looks better built/design to me ]
so I turn to my pears, I would like to hear honest reviews, both have good features . both are about the same price
   / 3 point wood chippers #2
Did you find this thread on TBN ? Chipper WoodMaxx WM-8H vs Woodland Mills WC86 - TractorByNet.com
TractorByNet.com | Compact tractor forums, news, reviews, information. › Forum › General Forums › Attachments
I have the WM8-H. My tractor only puts out 25 HP so I was limited to what I could buy. I really like my WM. Heavy duty and good features.
How much HP does your tractor put out ? That is important. I paid $3000 total...elected to go with a USA made PTO shaft.
that link doesnt take you to the article . I remember seeing that over a month ago when I started looking ,that's where I found woodlandmills . I buy and sell tractors so they always change, but I try to always have a 50+ hp tractor around ,- I do a lot of bushhog mowing in the summer, both of those units are right about $3000
   / 3 point wood chippers #6
I also looked at the WoodlandMills and the Woodmaxx. I like a lot of the design features of the WC88. But I went with the WM8H. The primary reasons were a level infeed hopper and easier feeding. The WC88's hopper is angled up. So if you have a long branch or tree you need to push it way up in the air to get it to feed. My old MacKissick had an angled hopper and it was a lot of effort to get long material high enough to feed. In videos it looks like the WC88 takes more effort to get the roller to grab larger material. It has a single feed roller while the 8H has two, and a lever you can pull to help the pivoting roller climb up on a large log. The WC88 doesn't have the lever so you have to push your larger material until it grabs. I chip a lot of long heavy pieces.
The WC88's feed hopper is at angle and sticks way out to the side. The 8H's hopper is straight but it's long. So with either one you have to be careful when backing up. I often park on roads to chip. Having to feed from an angle would mean parking at an angle or feeding material from off the road, which might be up or down a bank or in brush.
I like the WC88's better feed start/stop/safety lever and how the whole top of the rotor housing comes off to service the knives. The 8H has small doors to access the knives. They work ok but more access would be better.
The 8H comes with a flow control valve that's way too large. That makes it difficult to adjust the feed speed, especially at lower speeds. I replaced it with a lower flow valve which works much better. Cost about $120. It might be worth asking Woodland what GPM their flow valve is and what GPM their system is. The valve should be about 25% more. The 8H has a 3gpm system and comes with a 16gpm valve, which is way too big. They don't see it as a problem, I did (though not a huge one). I replaced it with a 4 gpm valve. If you're chipping small stuff and leave it on full speed you'll never notice. I've been chipping a lot of large stuff lately and need to adjust the feed rate more precisely.
Woodmaxx's HP ratings are optimistic. I have 32 PTO/ 37 engine HP and need to set the feed very slow for 6"+ material. Even then I need to stop the feed sometimes to let the tractor get the rotor back up to speed. I think Woodland's HP ratings are more realistic. I could use another 10hp for chipping the large stuff. Both units have the same chipping capacity. That's what consumes the power, so it doesn't make sense for one to need half the HP of the other.
The 8H has slots for the moving roller to move up and down. Sometimes material can wedge in there. It can take saws and chisels and a bit of disassembly to remove it. I have 40 hours on mine and it's happened five times. There is also a gap between the lower fixed roller and the bed knife. Material can hit that and jam, though reversing the feed will get it out and you can rotate it and try again. Wood that grows irregularly is more of a problem for both of these issues than stuff that's straight. I have been chipping madrone lately and it's the worst. It's very irregular. Pine's the opposite, it's rarely a problem.
thanks for the replys does anyone have a woodland mills ?? seem to see a lot of responces for woodmax
   / 3 point wood chippers #8
I have looked at both for a while and will probably get the WC88. I like how it looks and the build better. They have a bunch of very positive reviews on their site. I will probably get their PTO stump grinder also.
   / 3 point wood chippers #9
I have the Woodmaxx and would recommend it! Works great!
As for the slots- I have a tip: I had a weird branch catch in there twice. I now leave a battery powered Multi tool on the tractor just incase it happens. Only takes about a minute or two to cut anything that could get stuck in there and you are back underway.
Oscillating Multi-Tools | DEWALT
   / 3 point wood chippers #10
I have a Wallenstein BX62S. However, I've hear a lot of good things about Woodmax. Woodlandmills - just one of many I've never heard of.
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
Alligator Statue (A55853)
Alligator Statue...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52707)
2017 CASE IH 580...
KUBOTA M955 DUAL SPEED TRACTOR (A57192)
KUBOTA M955 DUAL...
