3 point usefulness on Ventrac?
   / 3 point usefulness on Ventrac? #1
ShowroomShine
Raleigh NC
2019 Case IH 55A
Being new to Ventrac and Steiner machines I’m seeing some Ventracs that have a 3 point hitch and most don’t.
Is the 3 point actually useful on these machines and worth trying to get one that has it or is it mostly for cargo hauling etc? I know ground engaging stuff like a box blade or something similar probably not the best on a Ventrac but I’m wondering what is actually used on it.
   / 3 point usefulness on Ventrac? #2
The only rear attachments I have seen on them is when used to groom baseball fields.
   / 3 point usefulness on Ventrac? #3
I have a box blade and a boom plus i made a ripper and all work ok with the hyd. top link......
   / 3 point usefulness on Ventrac? #4
I keep a Norwood "log hog" on it most of the time for skidding logs. I also use a cultivator and rake that were originally designed for Kolpin's ATV 3 point hitch. The cultivator works great for loosening things up for seeding. I use the rake reversed to cover seed, and in normal position for raking. The Kolpin rake is pretty light compared to most Cat 1 rakes so it can't move a whole lot before it fills up and jumps the pile, but a typical CAT1 rake is heavier than I'd care to drag around on rough terrain.
Occasionally I use the 3n1 adapter back there to bring the bucket or another Ventrac implement along to wherever I'm working. For what I do where I work in the woods I can't imagine not having the 3 point hitch.
   / 3 point usefulness on Ventrac? #5
I also use the 3n1 adaptor with the bucket on the back when i have the stump grinder on the front. Works ok to move chips out of the way. With bucket on the front and the box blade on the back i can grade and move a lot of dirt.
   / 3 point usefulness on Ventrac? #6
I do okay with this rear scraper blade.
   / 3 point usefulness on Ventrac? #7
I keep thinking about a front mounted 3P PTO driven attachment, that you can then add traditional cat 1 implements to! It probably hasn't been done for a number of very good reasons. But I have an old till and slasher that I would love to be able to use. The only non-powered 3P implement I have is a carry all, and I get by using the bucket and grapple attachment.
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
11 ft Shipping Container (A55973)
11 ft Shipping...
2012 MACK GU713 (A58214)
2012 MACK GU713...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
