3 point troubles
/ 3 point troubles #1
dbl A ron
Kubota L295DT
I have a kubota L295DT with loader, just recently i was rottertilling and when i was finished i went to lift the implement but it wouldn't raise. after trying a few times i noticed the top adjustable bar pin had come out half way and jammed it from moving up. Ok now thats the story and here is the symptoms. the 3 point won't lift unless at high idle and it won't lift my weight (230lbs). i added fluids and that did nothing. the loader and pto work fine can anyone tell me what i broke and how to fix it. thanks
/ 3 point troubles #2
Have you changed the filter? If this has a filter like the L245 it could be that simple.
/ 3 point troubles
nope but i will now thanks for your quick responce.
/ 3 point troubles #4
Is there knob/valve of some sort lets hyd. fluid follow to 3pth might of turn off/half way open...knob/handle on some models can be found under seat area.
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2019 Maxx-D 40' Gooseneck Trailer w/ Mega Ramps (A64047)
2019 Maxx-D 40'...
2025 40in Tilt Bucket Excavator Attachment (A61572)
2025 40in Tilt...
2024 John Deere 408R Sprayer (A63109)
2024 John Deere...
Coyote Renegade Trailer (A63116)
Coyote Renegade...
