3 point trailer mover
/ 3 point trailer mover #1
joeu235
Platinum Member
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
Needed a new trailer mover for the tractor. We use the tractor to move square bales on a 32 ft flat bed out of the field. Will eventually add a receiver tube on the bottom. Made of 3 x3 3/8 tube and some 3/8 and 1/2 plate.
/ 3 point trailer mover #2
/ 3 point trailer mover #3
Looks great... one of my favorite attachments!
One suggestion I would make, which I am about to do to mine (KK), is to build legs for the bottom. Something like two L-shaped pieces on the bottom for it to sit on, so it doesn't rest on the ground. I know they're not super heavy but it makes it easier to hook up, if you had a bumper pull receiver the receiver and ball drop/etc. out of the ground, and makes it compatible with a quick hitch.
/ 3 point trailer mover #4
Looks nic and heavy duty.
Curious why you bolted the tl bracket on instead of welding
The last failed at the top link attachment weld. This one is an improved design but I figured the bolts could better withstand the jerking motion of starting and stopping the trailer.
/ 3 point trailer mover #6
One of the handiest things to have. I built one (the green one) out of what I had laying around, whichs was 4"x4"x 1/4" square stock and some 1/2" and 3/4" plate. Really too heavy, I just wish I would have made it QH compatible. I recenlty added removeable silver hay spikes to the one I built and bought basically the same thing (balck one) with removeable hay spikes but lighter and QH compatible.
UNUSED WOLVERINE HYD CONCRETE CHUTER (A64281)
UNUSED WOLVERINE...
UNUSED AGT ATK-B1000 TWO-POST CAR LIFT (A64281)
UNUSED AGT...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63688)
Magnolia Trailer...
(1) 80" X 33" TAILGATE, APPROX (4) 48" X 60-79" (A64280)
(1) 80" X 33"...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
