LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,899
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Every once in awhile we need a trailer hitch on a tractor, modified a quick hitch a few years ago for gooseneck trailers.
But this year I thinking about doing away with the old plow truck that I haul my driveway sander on only put 56 miles on the truck last year,
and the insurance to keep it licensed is a few hundred dollars so it ends up being $4 to $5 a mile for insurance.
So going to put the sander on a trailer and made a hitch to easily hook up most any trailer to the tractor.
It's built a bit heavier then it needs to be as even the loaded sander on the trailer will only be 3-4 tons max,
but it will also be used on a 16,000 bumper pull and a couple of goosenecks at 16,000#, plus we tend to have some prety heavy loads once in awhile.
The chains visible in the 3rd picture run down to a clevis pined to the drawbar,
the chains act as a high limit for the hitch going up.
That way a trailer that tries to jump up when loading or going down hill can't lift the hitch to high and damage the tractors.
The clevis is temporary I'm going to build a box to slid on the drawbar and pin on with a hitch pin with the chain going under the box and welded to it.
It's built heavy enough that it should take anything that gets hooked or chained to it.
It has a couple of chain hooks welded to the risers for safety chains or if I wish to hook to something to pull it,
or I'll just chain around the framework anywhere.
