3 point slow
/ 3 point slow #1
Leadhead48
Tehachapi, Calif
F-1700
Need help I have 1700 ford the 3 point drop fast but take a long time before it will lift when I turn the flow control knob it will stop the 3 point from lowering as I turn the knob itwill lower fast but will lift slow very slow
/ 3 point slow #2
The purpose if the flow control/descent rate valve , is to lower an implement slowly. It is also used in the transport position to lock any flow from the 3pt cyl, so the implement does not accidentally drag or drop.
The raise speed is based on the pump pressure, and implement load, and 3pt valve lever position.
John Deere 5525 (A60462)
John Deere 5525...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Roll of Plastic Hose (A64119)
Roll of Plastic...
2012 Case SV300 Skid Steer (A63111)
2012 Case SV300...
UNUSED IRLMC DELUXE MASSAGE CHAIR (A64281)
UNUSED IRLMC...
1078 (A64280)
1078 (A64280)
