3 point slow
   / 3 point slow #1
Leadhead48
Tehachapi, Calif
F-1700
Need help I have 1700 ford the 3 point drop fast but take a long time before it will lift when I turn the flow control knob it will stop the 3 point from lowering as I turn the knob itwill lower fast but will lift slow very slow
   / 3 point slow #2
The purpose if the flow control/descent rate valve , is to lower an implement slowly. It is also used in the transport position to lock any flow from the 3pt cyl, so the implement does not accidentally drag or drop.
The raise speed is based on the pump pressure, and implement load, and 3pt valve lever position.
2012 Chevrolet Traverse LTZ SUV (A53424)
2012 Chevrolet...
Loflin 48 Inch Pallet Forks - Global Carrier (A55218)
Loflin 48 Inch...
2012 JOHN DEERE 410K BACKHOE (A51406)
2012 JOHN DEERE...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2010 Chevrolet Tahoe SUV (A52377)
2010 Chevrolet...
