3-point sensitivity adjustment
/ 3-point sensitivity adjustment #1
ritcheyvs
Kittrell, NC
Kioti DK45S
I recall seeing threads here complaining about a "bouncy" 3-point hitch. As far as I know, these MLS valves are similar on many Kioti models and that valve is adjustable to achieve smooth lift operation. Here is a video on adjusting the MLS:
Kioti CK2S Tractor MLS Valve Adjustment on three point hitch - YouTube
This is not to say that a MLS can't be defective or (more likely) a dealer doesn't know about adjusting them.
/ 3-point sensitivity adjustment #2
The MLS valve can be adjusted to stop the 3 point from bouncing, but the adjustment has nothing to do with your three-point coming up in a jerky motion.
/ 3-point sensitivity adjustment #3
If I don't lower rpm's, the hitch will come up to quickly for me. It happens a lot when I'm using a snowblower because the rpm's are 2500.. If I lower rpm's, it moves nicely..
/ 3-point sensitivity adjustment #5
I just bought a 2018 CK3510. I have been using the crap out of the york rake I have not experienced any bouncing with the 3 point hitch.
So far the tractor has been flawless, and couldn't be happier.
/ 3-point sensitivity adjustment #8
Kioti went to the Kubota type lift control valve that is now located internally so you are not able to adjust it w/o removing the 3ph lift arms and cover. Amazing Kioti has made this move when Kubota has had issues with this valve since 2013.
Arrow Board (A62613)
Deutz DX140 Tractor (A66285)
Deutz DX140...
1998 Mack DM690SX Chassis Truck  (A62679)
1998 Mack DM690SX...
2022 HAULMARK 14' T/A ENCLOSED TRAILER (A65643)
2022 HAULMARK 14'...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
