3 point raise and lower
/ 3 point raise and lower #21
GMtb42 said:
Ok will do !
Texas Dodge does yours raise from where you stop at ? , like if you stop at 4 on the scale does it move up immediately when you move it , or is there a dead spot before the lift raises again ?
It moves immediately.
/ 3 point raise and lower #22
There has to be some amount of gap between the two to keep the pump from going into constant pump. But, it does seem like yours may have a rather large amount.
GMtb42 said:
Correct , seems strange to me , shouldn't it lift from the stopped position as soon as you move the control lever ?
I know what you were saying if you let the implement all the way down and went to 1 on the scale there would be a dead spot until the control lever reached a point that started to raise the implement .
ccsial , said he tried it on his L3400 and his moves from the point the lift stopped at , hmmm .
/ 3 point raise and lower #23
As youy say, there has to be a bit of deadband, but there should not be much. Hardly enough to notice. That valve should servo very tightly. My 1910 is even tighter and smoother than the L3400.
It would be hard to do precise grading if there was much deadband.
Yeah kind of hard .
Dealer wants it back , but will not tell me what they are going to do .
But must have been something they did .
I will prod for info and see if I can get any .
/ 3 point raise and lower #25
I imagine they will get it fixed. Let us know.
Will do , thanks for your input as well .
Ok , as promised , I am reporting what the out come was .
The dealership said Kubota sent wrong valve to them so they had the replace the valve a second time , this time it works as it should . :D
Move the lift lever and it moves immediately , thanks everyone for the comments and looking at your tractor for reference .
/ 3 point raise and lower #30
Great to hear. Glad they got if fixed. Thanks for the update.
Landhonor 3-Pt PTO Potato Harvester (A66285)
Landhonor 3-Pt PTO...
2009 V.E. ENTERPRISES 130BBL VACUUM TRAILER (A65643)
2009 V.E...
2020 Cushman Hauler 1200X Gas Utility Cart (A64553)
2020 Cushman...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2003 CASE 70XT SKID STEER (A65053)
2003 CASE 70XT...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
