3 point problems on 851
/ 3 point problems on 851
OK, I pulled the side plug on the trans and a little fluid started coming out.
Then pulled the hyd drain plug and only fluid.???????
One of my neighbors has Allis C. tractors, big ones for tractor pulls, I ask him and he didn't seem to know much about toys. He did ask if there is an enternal hyd fluid filter that might be stopped up which would cause foaming..Geee I just don't know what to do here....
/ 3 point problems on 851 #22
no external hyd filter.
if there is no water in the hyds.. AND trans is at normal level, engine is at normal level, and diffy is at normal level.. thent he overfill int he hyds won't hurt anything.
if the 3pt is eratic.. you will actually haveto fix it.
top cover kit is about 15$
Problem solved. Replaced the pin (5/16" x 7/8" ), about 5 bucks and the cover gasket kit 15 bucks ( the only things that would fit, Oring for hyd. cyld. ) the main gasket even had to be trimed around bolt holes to work!!! It has made in USA stamped right on it, one would think better from our own people.
/ 3 point problems on 851 #24
I posted this in post #2,,, top cover kit and cam follower pin. ;)
Yes you did!!! But there are some of us that try all the easy ways first. You noticed, of course, I did ask a lot of questions. And by doing so I was able to learn some other things---YEAAAAAA!!
Thank all of you for your input on this matter. I was able the turn over some dirt today, I was singing in sunshine, I just love my tractor----Bye for now all, and again THANKS
2007 International 4300 Cab & Chassis 438418 (A62613)
2007 International...
1991 BMY 6x6 Wrecker (M936A2) (A62613)
1991 BMY 6x6...
2006 KOMATSU FD80T-8 FORKLIFT (A59914)
2006 KOMATSU...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
2007 Freightliner Columbia 120 Single Axle Day Cab (A62613)
2007 Freightliner...
