3 Point Not Working
/ 3 Point Not Working #1
BobEG
Kubota M5700
Need Help Please!!!
I have a Kubota M5700. I went to use the 3 point and it is stuck in the up position. It will NOT drop.
I've tried putting weight on it--300 lbs.
Have not used it for some months, but last time I used it with my box blade, it worked fine.
I NEED IT FOR A JOB MONDAY AM, CAN ANYONE HELP?
THANKS
BOB
/ 3 Point Not Working #2
Double check that flow rate knob in front of, and under the seat. It could have gotten shut off all the way.
/ 3 Point Not Working #3
There is a valve on my L3700 under the seat that adjusts the speed of the 3pt. If this valve is close, it will not allow the 3pt to operate. Check that first. If it is not closed, do a search on TBN and you will find a number threads regarding the 3pt valve and troubleshooting that is beyond my expertise. There will likely be something in those threads that will help narrow or remedy the issue.
Good Luck
