3-Point Hitch 3 point log splitter
   / 3 point log splitter #1
jermel8
Can a tractor mounted log splitter be hooked up to the front loader hydraulics? I have a TC31 New Holland. Jerry
   / 3 point log splitter #2
Welcome to TBN:D
Yes, you can hook it to your FEL outlets, you will just have to use a bungee cord to hold the joystick in a position that energizes the ports you hook the splitter into.
Do a search for "logsplitter" for hours of reading on the subject-and the controversy of 3PH mount splitters.
Thanks for the quick response,yes I did stumble onto the tractor hitch debate and now will have to do more thinking about my situation, Thank again, Jerry
   / 3 point log splitter #4
If you use the FEL ports, I'd be sure to stay away from the curl circuit. I'd put it in the lift cylinder circuit and pull the joystick all the way back to bungee it. If you push forward, you can get into float and have no pressure. If you use the curl circuit and move the joystick to dump position, you can get into regenerative feedback and cause problems. I think the lift circuit will be the least problematic if you do it right.
Thanks Jim for the good advice about the FEL hydraulics. Now I think, that since the TC31 has only a 7.2 gpm pump that a pto driven pump might be better. Jermel
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
2014 Ford F-250 (A55973)
2014 Ford F-250...
