3-Point Hitch 3 point log splitter
   / 3 point log splitter #1
jermel8
Can a tractor mounted log splitter be hooked up to the front loader hydraulics? I have a TC31 New Holland. Jerry
   / 3 point log splitter #2
Welcome to TBN:D
Yes, you can hook it to your FEL outlets, you will just have to use a bungee cord to hold the joystick in a position that energizes the ports you hook the splitter into.
Do a search for "logsplitter" for hours of reading on the subject-and the controversy of 3PH mount splitters.
Thanks for the quick response,yes I did stumble onto the tractor hitch debate and now will have to do more thinking about my situation, Thank again, Jerry
   / 3 point log splitter #4
If you use the FEL ports, I'd be sure to stay away from the curl circuit. I'd put it in the lift cylinder circuit and pull the joystick all the way back to bungee it. If you push forward, you can get into float and have no pressure. If you use the curl circuit and move the joystick to dump position, you can get into regenerative feedback and cause problems. I think the lift circuit will be the least problematic if you do it right.
Thanks Jim for the good advice about the FEL hydraulics. Now I think, that since the TC31 has only a 7.2 gpm pump that a pto driven pump might be better. Jermel
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
2019 International Bucket Truck (A55973)
2019 International...
Spirit scooter (A55787)
Spirit scooter...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2019 FREIGHTLINER...
2021 Ram ProMaster City Van (A56858)
2021 Ram ProMaster...
