3 point log spliter
/ 3 point log spliter #1
Leroy Brown
Kioti ck20
I have a CK 20 and am buying a log splitter for it. The question I have is do I have to add a rear remote? Or can I simply use longer hyd. Lines and attach to the quick disconnects that go to my FEL?
I don't have the rear remotes. That's why I was wanting to use the already existing hydraulic connections at the FEL.
/ 3 point log spliter #4
If you look at older threads, you will find many people use the loader connections. The catch is that you have to find a way to hold the valve open - not so hard if you have individual valve levers (bungee?), a bit harder if you have a "joystick" 4 way control. The additional rear remotes are very convenient if you can afford it.
/ 3 point log spliter #5
Well you could, but it is a pain to have to hook and unhook it when you want to use your loader plus it your loader doesn't have a detent to keep oil flow to your splitter. I would suggest putting on an scv kit. They are a snap to put on and you can always use it for other implements.
Well I truly appreciate all the input. I believe I'll take all your advice and just go ahead and install the rear remote. I think I was expecting to hear that advice to begin with. Thank again to all!
/ 3 point log spliter #8
Dj, is that what those schhhtoopid detents are for?
So if LB did use the FEl hook up with longer hoses a splitter would not work because the remote valve won't give it any fluid?
/ 3 point log spliter #9
I use the bucket cylinder connections on my JD 790. The "power beyond" kit is NLA, I was quoted nearly $1500 to "piece" the kit! I just use a tarp strap to the opposite fender from the joy stick. Works fine for me! ~~ grnspot
/ 3 point log spliter #10
KIOTI's remotes are MSRP for around $350 plus installation. We install them in about an hour of time. And yes all tractors need at least one remote.
Tony
2024 BIG TEX 102" X 25' GOOSENECK TRAILER (A65054)
2024 BIG TEX 102"...
2021 ASV RT-120 FORESTRY SKID STEER (A65053)
2021 ASV RT-120...
2020 CASE TV450B SKID STEER (A65053)
2020 CASE TV450B...
2019 Ford F-450 Liftmoore 1032 3,200lb. Crane Service Truck (A64556)
2019 Ford F-450...
Tropic Trailer (A64557)
Tropic Trailer...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
