3-Point Hitch 3 Point Linkage
   / 3 Point Linkage #1
Farm.E.R
I recently purchased a 2002 TC30 with 100 hours. It is missing the right-side leveling link (lift arm) to the 3 point hitch. The OEM (SBA370011581) part is about $200, which seems excessive... right now I have some chain as a substitute. Is there a reputable aftermarket source for this part... I have done some looking and have not come accross one yet.
I also have a slight, anti-freeze leak coming from the block. It seems to be pure antifreeze... any suggestions?
Thanks
farm.E.R.
   / 3 Point Linkage #2
I've found will fit stuff at tractor supply that needed very little hacksaw and welding to make them fit.
Find the location of the leak.. look for a freeze plug, block drain.. coolant petcock / bypas line.. etc..
radiator hose.. water pump... seam at the head.. crack in the block or the head.. etc..
soundguy
   / 3 Point Linkage #3
Thanks
farm.E.R.
Take the radiator cap off and inspect the antifreeze, Hopefully, you have no sign of oil. If so, that may be sign of cylinder head gasket issue. Pure antifreeze is better than antifreeze with oil sign.
JC,
   / 3 Point Linkage #4
I agree with JC about what the coolant looks like, if possible do a pressure test on the coolant sytem to see if you can see it leaking.
2018 John Deere TX (A53317)
2018 John Deere TX...
UNUSED FUTURE...
SHOP FAN WELDING CART (3) JACK STANDS (A54757)
SHOP FAN WELDING...
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
John Deere 5103 (A53317)
John Deere 5103...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
