3-Point Hitch 3 Point Linkage
   / 3 Point Linkage #1
Farm.E.R
I recently purchased a 2002 TC30 with 100 hours. It is missing the right-side leveling link (lift arm) to the 3 point hitch. The OEM (SBA370011581) part is about $200, which seems excessive... right now I have some chain as a substitute. Is there a reputable aftermarket source for this part... I have done some looking and have not come accross one yet.
I also have a slight, anti-freeze leak coming from the block. It seems to be pure antifreeze... any suggestions?
Thanks
farm.E.R.
   / 3 Point Linkage #2
I've found will fit stuff at tractor supply that needed very little hacksaw and welding to make them fit.
Find the location of the leak.. look for a freeze plug, block drain.. coolant petcock / bypas line.. etc..
radiator hose.. water pump... seam at the head.. crack in the block or the head.. etc..
soundguy
   / 3 Point Linkage #3
Thanks
farm.E.R.
Take the radiator cap off and inspect the antifreeze, Hopefully, you have no sign of oil. If so, that may be sign of cylinder head gasket issue. Pure antifreeze is better than antifreeze with oil sign.
JC,
   / 3 Point Linkage #4
I agree with JC about what the coolant looks like, if possible do a pressure test on the coolant sytem to see if you can see it leaking.
Brent 420 Grain Cart (A56435)
Brent 420 Grain...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2007 Ford F-150 (A55973)
2007 Ford F-150...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
Great Dane Van Trailer 1989 (A56435)
Great Dane Van...
