3 Point Lift
/ 3 Point Lift #1
Hinomotoman
Western NC
LS R3039, Hinomoto E2604, Hinomoto N239, Case IH 1140, White Field Boss 31
I have a Mitsubishi built Case International 1140. When the lift get up about 2/3 the way, it slows the engine down. When it passes this point, the engine resumes it's normal RPM's. It doesn't choke the engine completely down, just makes it lug. This happens with no implement on the lift. Any ideas what's wrong?:confused:
Eugene
/ 3 Point Lift #2
Is all the linkage connected correctly.
Is there any mechanical binding.
If operating the 3pt is causing the engine to load up, is related to the hyd flow against a resistance.
If you install a hyd gage in the hyd system, you can use it to monitor and trouble shoot the hyd system.
Will the 3pt lift a heavy load?
/ 3 Point Lift
All linkage is connected correctly. No mechanical binding. Will lift anything I have. Don't have a gauge yet. Once it gets past the 2/3 position, it turns back to normal the rest of the way up..
Eugene
2001 GMC C7500 Fuel Truck (A62613)
2001 GMC C7500...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
John Deere X380 Riding Lawn Mower (A66285)
John Deere X380...
